Calculating the diameter of a polonium atom
  • Thread starter Thread starter Jenkz
    Atom Diameter
The calculation of the diameter of a polonium atom, specifically ^{209}_{84}Po, is based on its mass density of 9.2 g/cm³. The volume was determined to be 22.7 cm³, leading to a calculated diameter of approximately 4.16 x 10^-10 m. The discussion highlighted the importance of using correct units, noting that expressing the diameter in angstroms (4.16 Å) is more practical. The final consensus confirmed the accuracy of the calculations with minor unit adjustments.
  • Understanding of basic chemistry concepts, specifically atomic structure.
  • Familiarity with density calculations and unit conversions.
  • Knowledge of the mole concept and Avogadro's number (6.02 x 10^23 mol^-1).
  • Basic geometry, particularly volume formulas for spheres.
  • Research the properties of polonium and its isotopes.
  • Learn about the significance of atomic radius in chemistry.
  • Explore the concept of packing efficiency in crystal structures.
  • Study the conversion between different units of measurement, particularly between meters and angstroms.
Chemistry students, physicists, and researchers interested in atomic structure and properties, as well as anyone involved in materials science and nanotechnology.
Jenkz
Polonium has a simple cubic structure at room temperature. Given that the mass density of solid [tex]^{209}_{84}[/tex]Po is 9.2gcm^-3 , calculate the diameter.
Volume = mass/density = 209/ 9.2 = 22.7 cm^3
1 mole = 6.02 x10^23 mol^-1
22.7 / 6.02x10^23 = 3.77 x10^-23 cm
volume = 4/3 (pi) r^3
So diameter is 4.16x10^-10 m ?
Is this correct? I have no answers to refer to. Thank you.
It looks absolutely correct to me.
Other than the third step where you (accidentally?) put "cm" instead of "cm^3"
But the answer I think is right.
Also, angstroms would be a more convenient unit, as it is 10^(-10)m.
so the answer could be:
4.16 angstroms
How would you stack balls so that they fill the whole space?
  • · Replies 16 ·
9K
