Gravity: Fictitious Force & Inertial Frame of Reference?
  • Context: Graduate
  • Thread starter Thread starter Red_CCF
    Couple
The discussion revolves around the nature of gravity as a fictitious force and its implications for inertial frames of reference. Participants explore the relationship between gravity, non-inertial frames, and the conditions under which Earth can be approximated as an inertial frame in various experimental contexts.
  • Some participants suggest that gravity is a fictitious force, drawing parallels to apparent forces experienced in an accelerating elevator.
  • Others argue that while the Earth is not an inertial frame due to its rotation around the Sun, it can be treated as approximately inertial for short-duration experiments where the effects of its acceleration are negligible.
  • A participant questions how the concept of "negligible" is defined in this context, referencing conflicting explanations found in textbooks regarding centripetal acceleration and gravity.
  • Some contributors clarify that the non-inertial nature of the Earth and the concept of gravity as a fictitious force are distinct, emphasizing that gravity can be treated as a force in inertial frame approximations during experiments.
  • There is a discussion about whether a stationary object on Earth can be considered a non-inertial frame solely due to the influence of gravity, with participants expressing varying levels of understanding and confusion regarding this point.
  • One participant raises a question about the nature of centripetal acceleration, suggesting that any change in velocity should imply a corresponding centripetal acceleration, prompting further inquiry into the definitions and implications of these concepts.
Participants express a mix of agreement and disagreement regarding the classification of gravity as a fictitious force and the conditions under which Earth can be treated as an inertial frame. The discussion remains unresolved, with multiple competing views on the implications of gravity and non-inertial frames.
Participants highlight limitations in understanding the definitions of "negligible" and the conditions under which gravity can be treated as a force in inertial frames. There is also an acknowledgment of the complexities involved in differentiating between the effects of Earth's rotation and the influence of gravity.
Red_CCF
I was reading stuff on fictitious forces and encountered a section that said that gravity was a fictitious force. I read a couple of websites but still didn't find a clear enough explanation on why this is true?
Also, if gravity is a fictitious force, then doesn't that mean that so long as we're under its influence we are in an non-inertial frame of reference? Then how is it possible that we achieve an inertial frame of reference on Earth if we're always accelerating?
Thanks.
Thanks.
Think of an elevator. If you weight yourself while the elevator is going upwards your apparent weight will be higher, i.e., it is equivalent to some kind of force pulling you downwards yet that force does not really exist, it is virtual. The same is true for gravity according to general relativity: the Earth is moving along the time-space structure which is equivalent to a virtual forced called gravity.
You are right, the Earth is not a inertial frame of reference. However, when the acceleration of Earth is negligible compared to the ones involed in your experiment you can approximate it for a inertial frame of reference.
I don't know if this is the deep of explanation you were looking for or you need something deeper.
Regards.
Regards.
Thanks for the response
I was wondering how this negligible is defined.
I've also been looking at some books which gave me more confusion. In a textbook they explain that it is because of the orbit around the sun that Earth is not an inertial frame of reference however they argue that because this centripetal acceleration is much less than gravity, Earth is essentially an inertial frame. I believe that they assume gravity was not a fictitious force, can someone clarify what they're trying to say?
You can say that for most of the experiments done, they have a comparatively short duration as compared to the period of revolution of the Earth (this time period links to the centripetal acceleration). Now, for the duration of the experiment, the Earth is almost moving along a straight line, with extremely small change in the tangential velocity component of the earth. Hence, for these durations, which are extremely small compared to the rotation of the Earth around the sun, we can consider the Earth as an inertial reference frame. But when we are talking about the gravity of the earth, then also we need to acknowledge the fact the experiments that are conducted are also within the accelerating frame of the earth. So, all the apparatus that we have in an experiment are at rest w.r.t. us and hence we can safely apply the laws of physics to these experiments, as would be done in an inertial frames, those experiments are done in a frame at rest w.r.t. us.
Okay so basically, because everything (experiment and say me as the frame of reference) is under the influence of the same acceleration due to gravity, essentially its effect can be neglected?
No. What Jivesh means is that there are two different concepts involved. On one hand is the non-inertial frame nature of the Earth because it is rotating around Sun. On the other is gravity which has nothing to do with the rotation but that came up in you OP question.
The Earth is non-inertial in general, but as Jivesh has explained, during most experiments lifetime it can be considered inertial. So, when you consider the Earth as an inertial frame the gravity is another force like any other.
A third concept is where de gravity comes form, which again has nothing to do with two previous concepts. Here is where my answer about space-time and gravity as virtual force fits.
I'm still a bit confused about the gravity part of my question and I guess I didn't understand your explanations clearly. So can one argue that a still object on Earth (perhaps a standing person) is a non-inertial frame based on the fact that he/she is under the influence of gravity (ignoring the fact that it's rotating around the Sun)? Why or why not?
For a circular motion, doesn't any infinitesimal change in velocity over an infinitesimal time have the same (or in a oval trajectory similar) centripetal acceleration? I thought that centripetal acceleration is constant for any change in velocity or am I mistaken?Thanks.
  • · Replies 137 ·
10K
  • · Replies 114 ·
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 69 ·
  • · Replies 18 ·
  • · Replies 78 ·
