| Thread Closed |
Rotating sphere |
Share Thread | Thread Tools |
| Jul6-10, 06:13 PM | #1 |
Rotating sphere
Hi all,
I am thinking about neutron stars and wondering about rotations at relativistic speeds. Consider a perfect sphere of radius R rotating about the Y-axis with the observer located along the +Z-axis. The outer edge of the sphere rotates with tangential velocity V and so from the observer's perspective the fastest transverse velocity occurs for the portion of the sphere located at (0,0,R) which has velocity (+V,0,0). So if you took a small finite strip of material along the X-direction at this location, with length L, it should get contracted to length L' = L/gamma. Now the next portion along will not be contracted by as much because the projected velocity in the X direction has now decreased. So does that mean that there exists a 'black spot' between these two shortened portions? How can the sphere be continuous, which of course it should be? Also, what would the general appearance of the sphere be? Does it becomes prolate and if so with what axes lengths? Finally, what about the Penrose-Terrel rotation? If each "strip" gets rotated by the Terrel angle, then it's projected length would be additionally shortened on-top of the length contraction effect. Natski |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Jul6-10, 06:30 PM | #2 |
| Jul6-10, 07:25 PM | #3 |
You might want to check out the final segment of this video: http://www.youtube.com/watch?v=JQnHT...eature=related
| Jul6-10, 07:51 PM | #4 |
Rotating spherePoint is... the strip moving fastest gets squashed a lot in the X-direction but the strip next door appears less squashed in X, and thus it seems that gaps should appear between strips - which of course cannot be the case... Natski |
| Jul6-10, 07:54 PM | #5 |
In regard to the "gaps" - I ahve just realized the solution, I think. It is not special to rotation, even a moving piece of metal, say, could be considered as a sequence of pieces of metal joined together and each piece is length contracted. So why don't gaps appears?
The answer is of course that the distance between each strip also contracts, as well as the strip lengths themselves. So now the outstanding question I pose is what is the appearance of the rotating sphere? My feeling is still a prolate spheroid... but I would like to see a proof. Natski |
| Jul6-10, 08:33 PM | #6 |
| Jul6-10, 09:13 PM | #7 |
The reference is to R. Penrose, "The apparent shape of a relativistically moving sphere," Proc. Camb. Phil. Soc. 55, 137 (1959). |
| Jul7-10, 01:43 AM | #9 |
[QUOTE=kev;2790175]It is known that the Earth is a prolate sphere and that the diameter at the Equator is significantly larger than the Pole to Pole Diameter. This is pretty much what you would expect from newtonian cetripetal considerations. What is interesting from the GR point of view is that even though the tangetial velocity is greatest at the Equator (and therefore the time dilation due to kinematic effects is greatest there), clocks at sea level anywhere in the world all run at the same rate. This is no coincidence. Sea water effectively moves from where time runs fastest (high effective gravitational potential) to where the time dilation is the greatest (low effective gravitational potential) until the effective potential at sea level is the same everywhere and then 1) the process stops.[/QUOTE]
Agreed it is interesting that clocks at sea level all have an equal dilation factor but : ) how is it possible that 1 ) the process stops??? At the equator there is always the sea level difference in altitude (r) isnt there ? It seems like it just moves continually relative to the terrain and at rest wrt the moon. Or am I misunderstanding you ?? |
| Jul7-10, 01:51 AM | #10 |
If I remember Penrose right; that also dealt with translation and the effect was based on propagation time offsetting contraction ??? If this is right then neither would seem to apply in this situation where the observer is at rest wrt the rotation axis , so if there was optical or physical deformation the difference in propagation time wouldn't have any effect. |
| Jul7-10, 08:15 AM | #11 |
| Jul7-10, 08:27 AM | #12 |
If the OP wants to know whether it applies when the sphere is rotating and the observer is at rest with respect to the axis, he should definitely look up the Penrose paper at the nearest university library. This pdf physnet2.pa.msu.edu/home/modules/pdf_modules/m44.pdf reproduces the abstracts of several old papers on this topic. |
| Jul7-10, 08:36 AM | #13 |
Thanks for the Penrose reference.
It the Penrose sphere is indeed translating and rotating, then the solution is that the sphere remains a sphere. Is this generally true of any ellipsoid? A further question regarding pure spheres... imagine a grid of longitude and latitude on the sphere. Even if the sphere's outline does not become distorted, does this grid become distorted tom degree? Natski |
| Jul7-10, 08:39 AM | #14 |
| Jul7-10, 08:56 AM | #15 |
However, if the centre of the sphere gets contracted, there must be some counter-balancing expansion at a different part of the gird or the sphere would no longer remain a sphere. This therefore means that a) the sphere does become distorted or b) the grid does not become distorted. The two cannot be commensurable. |
| Jul7-10, 09:07 AM | #16 |
| Jul7-10, 09:43 AM | #17 |
Having thought about this a little more, I think I understand this better. Let's distinguish four cases: A. The sphere is not rotating. The sphere's center is at rest. The observer is moving in a straight line. B. The sphere is not rotating, but its center is moving in a straight line. The observer is at rest. C. The sphere is at rest and not rotating. The observer moves around it in a circle with its center coinciding with the center of the sphere. D. The sphere is rotating, with its center at rest. The observer is at rest. A and B are equivalent under a Lorentz transformation. The Penrose result clearly includes these cases. The outline of the sphere is still spherical. C is also equivalent to A and B, because there are only two effects (Lorentz contraction and optical aberration), and both of them depend only on the observer's instantaneous velocity, not on his history of motion. This proves the result asserted in the commentary to the ANU video. D is not a well-defined question. When asking this question, we're implicitly assuming that the sphere has some well-defined "real" shape, which appears different because the sphere has been set into motion. But you can't impart an angular acceleration to a perfectly rigid body in relativity. A more well defined case is: E. A rotating, self-gravitating body is in hydrostatic equilibrium. What is its shape as perceived by an observer at rest with respect to the body's center of mass, and how does this compare with the shape that would be inferred by observers surveying the body's surface with co-moving meter-sticks? In case E, the observer clearly sees an oblate ellipsoid, because the oblateness is a nonrelativistic effect, which is much, much stronger than any of the relativistic effects. The question is then whether relativistic effects modify this slightly, and in what way. I don't know whether it's valid here to make the approximation of ignoring gravitational aberration of light. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Rotating sphere
| particle rotating around a sphere | Advanced Physics Homework | 0 | ||
| Energy of a solid rotating sphere | Introductory Physics Homework | 2 | ||
| Rotating rigid sphere stress-energy tensor | Special & General Relativity | 4 | ||
| [electrodynamics] rotating hollow sphere | Advanced Physics Homework | 4 | ||
| Rotating dielectric sphere : Jackson 6.8 | Advanced Physics Homework | 2 | ||
