Free variables in linear algebra?
In summary, you can determine the number of free variables in a matrix by subtracting the number of independent equations from the number of unknowns. In the given matrix, there are four variables and only three independent equations, so there is one free variable. It is usually most convenient to choose the free variable as one that does not correspond to a pivot column. In this case, x4 would be the best choice.
TheColorCute
My questions is short and to the point: What exactly is a free variable (in a matrix, for example).
How do you know if a variable is free?
Here's a matrix that (apparently) has a free variable:
[1 4 -3 0 0]
[-2 -7 5 1 0 ]
[-4 -5 7 5 0 ]
Row reducing the matrix we end up with:
[1 4 -3 0 0 ]
[0 1 -1 1 0 ]
[0 0 6 -6 0 ]
Apparently this matrix has a variable. Where is it and how do I know that it's free?
Thanks! :)
Generally, if you have m unknowns and n independent and consistent equations, where n≤m, you have m-n free variables. Reducing a matrix allows you to find out how many equations you have that are actually independent. In your example, you have 4 variables and only 3 independent equations, so one variable is free.
Which variable is free is arbitrary. You get to choose, but when you have a reduced echelon matrix, it makes sense to use the variables that don't correspond to pivot columns, just because it makes the algebra more straightforward.
Ohhhh OK. So, to clarify, in this matrix we have 5 columns (but only four of which have constants in them), so we have four variables. Then we have three rows (each row equals an equation). So we have 4 variables minus 3 rows which is equal to 1 free variable. We don't want to choose any position in the pivot columns as free variables, so that eliminates columns 1, 2, and 3. So that leaves us with columns 4. So we could choose either x3 or x4 as our free variable? Or are they both free variables? Can we only have one?
The convenient choice would x4. In this particular case, since they turn out to be equal to each other, you could use either x3 or x4 pretty easily, but it's one or the other, not both. Generally, though since there's a pivot in the third column, you wouldn't use x3.
All five columns have constants in them. The other posters in this thread are assuming that your matrix is an augmented matrix that represents the matrix equation Ax = 0. Augmented matrices usually have a dotted vertical line separating the coefficients of the matrix from the column of constants, something like this:
[1 4 -3 0 | 0]
[-2 -7 5 1 | 0 ]
[-4 -5 7 5 | 0 ]
The elements of A make up the first four columns. The elements of the zero vector are fifth column.
1. What is a free variable in linear algebra?
A free variable in linear algebra is a variable that is not restricted by any equations or constraints in a system of linear equations. It can take on any value and does not affect the solutions of the system.
2. How do you identify free variables in a system of linear equations?
To identify free variables in a system of linear equations, you can use the row reduction method to convert the system into an equivalent matrix form. The columns that do not have a pivot element are the columns that correspond to the free variables.
3. How do free variables affect the solutions of a system of linear equations?
Free variables do not affect the solutions of a system of linear equations. They represent additional degrees of freedom in the system and do not change the basic structure of the solutions.
4. Can a system of linear equations have more than one free variable?
Yes, a system of linear equations can have more than one free variable. The number of free variables is equal to the number of columns in the coefficient matrix that do not have a pivot element.
5. How can free variables be used in applications of linear algebra?
Free variables can be used to represent parameters or unknown quantities in real-world problems. For example, in systems of equations representing chemical reactions, free variables can represent the unknown quantities of reactants or products.
