The spinning, levitating orbiting card trick ?
  • Thread starter Thread starter Point Conception
    Spinning
The discussion revolves around the mechanics and methods behind the spinning, levitating orbiting card trick. Participants explore various explanations, techniques, and resources related to performing the trick, with a focus on both the practical aspects and the secrecy often associated with magic tricks.
  • Meta-discussion
  • One participant requests a detailed explanation or video of the trick.
  • Another participant humorously declines to share the method, citing the secrecy of the magician's community.
  • A link to a video demonstration of the trick is provided by a participant.
  • Several participants suggest that fishing line is commonly used to create the illusion of levitation.
  • One participant describes a more sophisticated version of the trick that allows for 360-degree movement around the performer.
  • A detailed method for performing the trick is shared, involving a black stocking, adhesive clay or tape, and a playing card, along with instructions for setup and performance.
  • The same participant notes that this trick is widely known and can be learned through various resources, including magic kits available for purchase.
Participants express differing views on the secrecy of magic tricks, with some emphasizing the importance of keeping methods confidential while others argue that such information is readily available and should not be a secret. The discussion includes multiple proposed methods for performing the trick, indicating a lack of consensus on the best approach.
The discussion includes various assumptions about the materials and techniques used in magic tricks, as well as the cultural norms surrounding the sharing of such information. There are unresolved questions about the effectiveness and originality of different methods proposed.
Individuals interested in magic tricks, performance art, or the mechanics of illusions may find this discussion informative.
Point Conception
Does anyone have the explanation for the spinning, levitating orbiting card trick ?
Please be more detailed, preferably with a video or a link to a detailed description of this trick.
You seriously expect me to tell you?
Trade secret mate! The Magician's Circle would string me up.
https://www.youtube.com/watch?v=pm8BuYDQ1-c
Hahahaha I remember doing this trick. A piece of fishing line is taped to the back of the card, and around the finger.
That's exactly what I was thinking upon seeing the video.
Ok I have the references for the source of my question , that I saw doing this card trick live. This is much more sophisticated than most as he can 360 the card all the way around himself.
See. the many: youtube walking street pattaya magic man,
youtube walking street pattaya magician
And while were on walking street the guys do not want to miss:
youtube walking street club 66
To perform this trick requires 3 items:
-A black stocking
-A small piece of adhesive clay or a small piece of transparent tape (scotch tape)
-A playing card
First you must prep the stocking. What you do is cut a length of stocking along the 'grain'. If you look at the end of the strip of the stocking you can see that the strip contains very small strands. You have to free one of those strands. The fact that the strand is black means that it absorbs light and thus is nearly invisible.
Now you tape or use the adhesive clay to attach the strand to the back of your ear. Tape or stick the other end to the middle of the card (on the back of the card in the dead center...the card should be dead centered so that when dangled it will be completely level). At this point you can perform your trick.
You can also be a little more innovative and instead of attaching the end of the strand directly to the card, attach it to..say..your belt buckle using the clay. Then you can ask an observer to provide you with any item or a playing card. Use some slight of hand (diversion) to pull attention away, and remove the end of the strand from your belt and attach it to the card or object. Now you can add some effect and make it float, orbit, or levitate. Before you hand the object back to the observer, remove the adhesive clay (and thus the strand) so they can inspect it.
MAGIC!
EDIT: This is a common trick. If a magician gets mad that I posted this, they need to do a simple Google search. You can buy levitation kits at any mom and pop Magic shop. The kits include the above stuff along with a video or instruction of sort. In this age of information, we can't expect things like this to stay a secret. I think this is great though. It forces magicians and performers to actually come up with something new and innovative.
  • · Replies 25 ·
