What are the prime numbers that satisfy k²=n³+1 when n is not a prime number?
The discussion revolves around finding prime numbers \( k \) that satisfy the equation \( k^2 = n^3 + 1 \), where \( n \) is specified to be a non-prime number. Participants explore the implications of this equation and the characteristics of prime numbers in relation to it.
  • Participants discuss the nature of prime numbers and their properties, particularly focusing on the equation \( k^2 = n^3 + 1 \). They consider the implications of \( n \) being a non-prime number and explore various algebraic manipulations and factorizations. Questions arise regarding how to connect different pieces of information and the implications of divisibility.
The discussion is active, with participants providing hints and exploring different approaches. Some participants have attempted to derive relationships between \( n \) and \( k \) based on the equation, while others suggest examining specific cases to ensure completeness in their reasoning. There is a recognition of the need to verify assumptions and explore multiple scenarios.
Participants note that \( n \) must be a positive natural number and that all prime numbers except 2 are odd. There is also a correction regarding the number of divisors of \( k^2 \), which some participants initially miscounted. The exploration of cases where \( n \) takes on specific values is also mentioned.
TrifidBlue
If k is a prime number
find all k that satisfy k²=n³+1
I really have no idea, use any suitable one
all prime numbers are odd except 2.
n must be positive natural number
n³ = k² -1 = (k-1)(k+1)
any help is appreciated
Two things you need to know to solve this problem:
1) If k is prime, then k^2 can only be divided by 4 numbers, 2 of which are k^2 and 1.
2) a^3 + b^3 = (a^2-ab+b^2)(a+b)
If you need more clues, ask, but post anything you did with these clues:)
-Tusike
-Tusike
thanks I'll try these hints
I tried with these two clues,
k^2 = (n+1)(n^2 -n+1)
k = sqrt [(n+1)(n^2 +n+1)]
and from clue (1) k^2 can be divided by k^2 , 1, k and -k
but I don't know how to connect the information together to get the answer :(
Ugh sorry, I said something wrong
k^2 can only be divided by 3 numbers, not 4 (I was thinking how it can be written down two ways as a multiple of two numbers...) . So what does that say about (n+1) and (n^2 -n + 1)?
k^2= (n+1) [ n(n-1) +1]
that is
k^2 = n (n+1)(n-1) + (n+1)
right?
You don't need to solve that equation just yet, only see how it can happen.
On the left side, you have k^2, and on the right side you have a multiple of two whole numbers, (n+1) and (n^2 - n + 1).
You know that k^2 can either be written as 1*k^2, k^2*1, or sqr(k^2)*sqr(k^2). These are also multiples of two whole numbers! So just pair them up:) You should get n=2, and from then k=3. 1*k^2 and k^2 * 1 won't lead to anything worth noticing.
EDIT: sqr(k^2), not sqr(k), sorry...
thaaaaaaaaaaaaaank you!
please check the steps
(n+1) = k
(n^2 -n +1) = k
n^2 -n +1 = n+1
n(n-2)=0 n=0 , k=1 (not prime)
n=2 , k=3
Yes, that is correct. Now I don't know about how "precise" this proof has to be, but if has to be really precise, you might want to examine the following two possibilities as well:
(1)
(n+1) = 1 and (n^2 - n + 1) = k^2
(2)
(n+1) = k^2 and (n^2 - n + 1) = 1
From the first you'll get that n = 0 and k = 1, which of course isn't prime, so that's not a good solution.
From the second, you'll get that n = 1, and k=sqr(2), which again isn't prime. However, you couldn't of known that you won't get valid solutions from these two, so I think they need to be added to the proof as well to make it complete.
Thank you very much,Tusike
^_^
  • · Replies 24 ·
  • · Replies 34 ·
9K
  • · Replies 19 ·
