Damping ratio from transfer function
The discussion centers on calculating the damping ratio from the transfer function defined as (23.23*s + 1.421) / (s^2 + 25.88*s + 1.421). The user, sgsawant, expresses concern about the non-zero coefficient of "s" in the numerator affecting the calculation of the damping ratio using the formula 25.88 = 2 * zeta * omega. The conversation highlights the importance of distinguishing between the coefficients that determine system zeros and those that determine poles, which ultimately influence the system's response characteristics.
  • Understanding of transfer functions in control systems
  • Knowledge of damping ratio and its significance in system response
  • Familiarity with poles and zeros in control theory
  • Basic algebraic manipulation of equations
  • Study the derivation of damping ratio from transfer functions
  • Learn about the impact of poles and zeros on system stability
  • Explore MATLAB or Python for simulating transfer functions
  • Investigate the effects of different damping ratios on system response
Control engineers, system analysts, and students studying control theory who are looking to deepen their understanding of transfer functions and damping ratios.
sgsawant
I have a transfer function for system.
23.23*s + 1.421
------------------------------------- = tf
Since the numerator has a non-zero coefficient for "s" I am wary about equating
25.88 = 2 * zeta * omega [the stuff we usually do for calculating the damping ratio].
Can someone shed any light on this?
Regards,
-sgsawant
N.B.: I this question is a copy of the one I asked on the General Forum. I wanted to switch it from General to Classical but couldn't find a way. Please guide if you know.
Can you divide top and bottom on the left side of the equation by 23.23 to get rid of the unwanted coefficient??
I believe that damping ratio is found in the same way. The numerator coefficients set the system zeros, but the denominator coefficients set the poles which control the character of the response (overdamped, underdamped or critically damped).
54K
  • · Replies 131 ·
9K
18K
65K
