An object travelling away from earth
  • Thread starter Thread starter Mu naught
    Earth
This discussion focuses on calculating the time it takes for an object shot away from Earth to reach zero velocity, considering the changing acceleration due to gravity as a function of distance (r). The conservation of specific orbital energy is central to the analysis, represented by the equation (1) \(\frac{1}{2}v^2 - \frac{\mu}{r} = E = -\frac{\mu}{2a}\), where \(\mu = GM_{earth}\). The discussion also highlights the distinction between rectilinear and orbital trajectories, providing formulas for apogee and perigee distances. The complexity of deriving an analytical solution for time in orbit is noted, emphasizing the necessity of calculus knowledge.
  • Understanding of gravitational forces and central gravity fields
  • Familiarity with orbital mechanics and conic sections
  • Knowledge of calculus, particularly in relation to motion equations
  • Proficiency in using energy conservation principles in physics
  • Study the conservation of energy in orbital mechanics using specific examples
  • Learn about the mathematical derivation of conic sections in orbital trajectories
  • Explore the calculus of motion in non-linear gravitational fields
  • Investigate the analytical solutions for two-body motion problems in physics textbooks
Aerospace engineers, physicists, and students studying orbital mechanics or gravitational physics will benefit from this discussion, particularly those interested in the dynamics of objects in motion away from Earth.
Mu naught
Say I have an object which has been shot away from Earth at some initial velocity, and I want to find out how long it will take until it's velocity is zero.
If it is moving fast enough, the approximation v = v0 + aΔt doesn't work because the acceleration due to gravity is changing as a function of r. I want to describe v as a function of t, set v equal to zero and solve for t.
This is the attempt I have made to solve this:
[PLAIN]http://img204.imageshack.us/img204/2879/problemw.png
Any suggestions?
Free falling objects in a central gravity field follow an orbit with can be described as a conic section (ellipse, parabola, hyperbola) and you can then relate the distance and speed of the object at any given time to the size of that conical section, [itex]a[/itex] by observing that the specific orbital energy (equal to the total mechanical energy per mass [itex]E[/itex]) of the object is conserved as
(1) [tex]\frac{1}{2}v^2 - \frac{\mu}{r} = E = -\frac{\mu}{2a}[/tex]
where [itex]\mu = GM_{earth}[/itex]. If [itex]E < 0[/itex] the orbit is a bound elliptical orbit and the object will have zero radial speed at farthest point in orbit, called apogee [itex]r_a[/itex] and at its closest point, called perigee [itex]r_p[/itex], and those two distances are related to the size of the orbit by [itex]2a = r_a + r_p[/itex].
It is not clear from your description if you want to shoot the object straight away from the Earth in a recti-linear orbit (i.e. "straight up") where perigee approaches zero or if the object is in a more realistic orbit (inserted from low Earth parking orbit) where perigee is close to the initial distance, but if we assume the last (that is, [itex]r = r_p[/itex]) then you can insert this into (1) and solve to get
(2) [tex]r_a = -\frac{\mu}{E} - r[/tex]
If you really do mean a recti-linear orbit then inserting [itex]r_p = 0[/itex] gives
(3) [tex]r_a = -\frac{\mu}{E}[/tex]
Hope this helps, otherwise feel free to ask. By the way, the subject is very standard and it should be easy to find a more detailed explanation for two-body motion problems in a great number of physical textbooks and on the net.
The answer for distances is a fairly simple polar equation describing a conic section (Circle, ellipse, parabola or hyperbola). That way you can tell the distance of an object in orbit (Either open or close) as a function of the angle relative to the major axis of the curve.The question of time in orbit, however, is a very different, and much more difficult one.
http://en.wikipedia.org/wiki/Free_fall#Inverse-square_law_gravitational_field
It requires quite a bit of knowledge in calculus, and I'm not sure if an analytical solution in elementary functions exists for the case of non-zero initial tangential velocity.
If you know the separation at 0 velocity (Readily available from the energy equation [tex]U/m=-\frac{GM}{y_0}+\tfrac{1}{2}v^2=-\frac{GM}{r_f}[/tex], setting v to 0 to find the distance at which the velocity is 0) then you can calculate the time for the separation to reach that final value starting with an initial separation [tex]y_0=R_{earth}[/tex]
  • · Replies 38 ·
  • · Replies 38 ·
