Range of a Matrix Transformation linear algebra
The discussion centers on the linear algebra problem involving the matrix A = [1 -3 -4; 0 1 (6/7); 0 0 0] and the vector b = [b_1; b_2; b_3]. It is established that there is no solution to Ax = b for all b in R3 due to the condition b_3 - 5b_1 - 14b_2 = 0, which must hold true for a solution to exist. The set of all {b1, b2, b3} for which Ax = b has a solution is described as b_3 = 5b_1 + 14b_2, indicating a linear relationship among the components of b.
  • Understanding of linear transformations and matrix equations
  • Familiarity with row reduction techniques in linear algebra
  • Knowledge of pivot positions in augmented matrices
  • Ability to interpret geometric representations of solution sets
  • Study the implications of row echelon form in linear systems
  • Learn about the geometric interpretation of solutions to linear equations
  • Explore the concept of linear dependence and independence in vector spaces
  • Investigate the conditions for consistency in systems of linear equations
Students and educators in linear algebra, mathematicians analyzing matrix transformations, and anyone seeking to understand the conditions for solutions in linear systems.
SpiffyEh
Given,
A =
[ 1 -3 4;
-3 2 6;
5 -1 -8]
b =
[b_1;
b_2;
b_3]
Show that there does not exist a solution to Ax = b for every b in R3 and describe the set of all {b1,b2,b3} for which Ax = b does have a solution.
row reduction
I row reduced until I got the following augmented matrix:
[ 1 -3 4 | b_1;
0 1 (-18/7)| (b_2 + 3*b_1)/7;
0 0 8 | b_3-5*b_1 - 14*b_2]
I'm confused about this because I was lead to believe that since there is a pivot for every value then there should exist a solution for every b in R3. And There is in fact a pivot in every row. Can someone explain to me if there is a solution or not and why please. I'm just not seeing why there wouldn't be one. Thank you
Are you sure you wrote down the matrix correctly? In particular, is the 4 in the first row supposed to be a -4?
oops, wow I feel dumb. I even double checked it. So, I had the right idea at least right?
ok so with that -4 in place I got the matrix to be:
[ 1 -3 -4 | b_1;
0 1 (6/7)| (b_2 + 3*b_1)/7;
0 0 0 | b_3-5*b_1 - 14*b_2]
from this i can see that there isn't an answer for all b in R3. The 2nd part of the question asks "describe the set of all {b1,b2,b3} for which Ax = b does have a solution"
this would be where b_3-5*b_1 - 14*b_2 is equal to zero. Otherwise there would be no solution. Would I just write this or do i need to say something about b1 and b2? Would i need to say that b1 and b2 could be anything? Or how would I go about saying that?
It depends on what "describe" means here. You might be expected to give a geometric interpretation of the solution set.
[ 1 -3 -4 | b_1;
Good: b_3- 5b_1- 14b_2= 0 and you can write that as b_3= 5b_1+ 14b_2 so that
\begin{pmatrix}b_1 \\ b_2 \\ b_3\end{pmatrix}= \begin{pmatrix} b_1 \\ b_2 \\ 5b_1+ 14b_2 \end{pmatrix}= b_1\begin{pmatrix}1 \\ 0 \\ 5\end{pmatrix}+ b_2\begin{pmatrix}0 \\ 1 \\ 14\end{pmatrix}.
Geometrically, what is that?
  • · Replies 24 ·
