Intersection of ellipses and equivalent problems
Determining whether two ellipses intersect can be simplified without solving complex 4th order polynomials. The discussion highlights the use of discriminants and Cartesian coordinates to transform the problem into a more manageable quadratic equation. The proposed method involves substituting one ellipse's equation into the other, ultimately leading to a numerical solution using online tools. This approach streamlines the intersection determination process significantly.
  • Understanding of quadratic equations in two variables
  • Familiarity with Cartesian coordinate transformations
  • Basic knowledge of discriminants in polynomial equations
  • Experience with numerical methods for solving equations
  • Research methods for solving quadratic equations in two variables
  • Explore Cartesian coordinate transformations in geometry
  • Learn about discriminants and their applications in polynomial equations
  • Investigate numerical solution techniques for intersection problems
Mathematicians, geometry enthusiasts, and software developers working on computational geometry or graphical applications that require intersection detection of ellipses.
Gerenuk
Does anyone know how to determine whether two ellipses intersect? I don't need the precise points but rather only the answer whether there are points. All my attempts led to 4th order polynomials, which are heavy to solve, but considering that I don't need the actual points I assume there must be an easier way.
Some guy claims it's doable
http://www.cut-the-knot.org/htdocs/dcforum/DCForumID6/710.shtml
Here are some equivalent problems which have to be solved for the angles (which however I can't solve either...)
[tex]\cos\phi+a\sin\theta=x[/tex]
[tex]\sin\phi+b\cos\theta=y[/tex]
or even
[tex]\Re(e^{i\theta}(1+ze^{i\theta}))=q[/tex]
where z is complex, is an equivalent problem. Any ideas?
My best attempt so far was using discriminants, but it's messy and I made a mistake somewhere...
Mathematics news on Phys.org
I would eliminate the angles by squaring and write the equations in Cartesian coordinates. Then we have still a quadratic equation in two variables, which one can be normalized by a coordinate transformation, such that we end up with ##y=\pm \frac{b}{a}\sqrt{a^2-x^2}## with one of the two ellipsis. This can be substituted into the other equation, such that we have only one equation in ##x##. It is probably easiest to determine it numerically by one the tools available on the internet.
