Algebra of the Henderson-Hasselbach equation
  • Thread starter Thread starter helpme12345
    Algebra
The discussion focuses on applying the Henderson-Hasselbalch equation to calculate the volumes of 0.1 M phosphate solutions needed to prepare buffer solutions with specific pH values (6.0, 6.5, 7.0, 7.5, and 8.0) using 0.1 M stock solutions of NaH2PO4 and Na2HPO4. The relevant reaction is H2PO4- → HPO4^2- + H+. The pKa value of 7.21 is provided, and the equation pH = pKa + log{[A-]/[HA]} is utilized to determine the necessary ratios of the phosphate stock solutions. The process involves isolating known and unknown values, applying logarithmic inverses, and calculating the required volumes for each buffer solution.
  • Understanding of the Henderson-Hasselbalch equation
  • Knowledge of pH and pKa concepts
  • Familiarity with buffer preparation techniques
  • Basic algebra skills for logarithmic calculations
  • Learn how to manipulate the Henderson-Hasselbalch equation for different buffer systems
  • Study the preparation of phosphate buffers in laboratory settings
  • Explore the implications of pH on biochemical reactions
  • Investigate the use of calculators for logarithmic functions in chemistry
Chemistry students, laboratory technicians, and anyone involved in buffer preparation and pH management in biochemical applications.
helpme12345
I am weak on the algebra of the Henderson-Hasselbach equation.
I have a prelab question:
Using the H-H equation, calculate the volumes of 0.1 MM phosphate solutions to mix to prepare 100ml each of buffers with pH values 6.0, 6.5, 7.0,7.5, and 8.0 starting with 01.M stock solutions of NaH2HPO4 and Na2HPO. The relevant reaction is given below:
H2PO4- -->HPO4^2- + H+
The pKa is 7.21.
I know the pH is the values listed.
pH=pKa+log{[A-]/[HA]}
How do I start this problem?
Chemistry news on Phys.org
You know the pKa, and you know what the pH needs to be for each of the buffers. What you need to know is the ratio of the phosphate stock solutions, so you can then mix up the appropriate volumes. So, you get your known values on one side and your unknown values on another side. Once you have that, you need to get rid of the logarithm (base 10) using its inverse. Once you've done that, then it's just a matter of calculating what the ratio is equal to (which you should be able to do on a calculator, it'll be a little messy) and then figuring out the appropriate volumes, dilutions, and the rest.
I hope this helps without giving too much away...
9K
  • · Replies 16 ·
