New Reply
HP50G Quick Question...
Share Thread Thread Tools
Jul18-10, 11:25 PM   #1
Hi,
I can't seem to get the HP50G to give answers in decimal regularly.
I'm in scientific mode but for instance can only get 13750/119 to appear as 13750/119...
This happens every once in a while and I can't find a command like on the Ti84+ that will force a decimal out of it...
Any help appreciatted,
Whalstib
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jul19-10, 09:41 AM   #2
Mentor
Can't you get it to just do plain old division? I haven't used an HP calculator for a long time, but the last one I had used reverse Polish notation (RPN). If that's what yours uses, you can get it to do division something like this:
13750 [Enter]
119 [Divide]
Jul19-10, 10:05 AM   #3
Quote by Mark44 View Post
13750 [Enter]
119 [Divide]
Nope,
Give the same result...
I found that Mode>CAS and selecting "approximate" gives a decimal answer.
You'd think that the calculator would be smart enough to know that if your using scientific you'd probably shy away from fractions.....Or at least have a quick command to convert.
This is why I like the HP35s. It defaults to decimals but if you enter .26.567 the display is 26/567
W
Jul26-10, 11:27 PM   #4
Quote by Whalstib View Post
Hi,
Whalstib
Use: [right-shift] [enter] to convert to decimal. Please note that if you press and hold the [right-shift] key, you will actually switch modes from exact to approximate (so that all subsequent calculations are converted to decimals). This can be toggled and you should see the top of your display change from [tex]\approx[/tex] to [tex]=[/tex]
Jul31-10, 09:11 PM   #5
i2c
Maybe once you get the answer in fraction form, try dividing it by 1.0 That works on my TI-89 when it spits a fraction back at me and I want it in decimal form.
Nov7-10, 01:40 PM   #6
When the calculator is in exact mode you can also put a . at the end of one of the numbers and it will give you a decimal. For example type 2. [enter] 5 [divide]
New Reply
Thread Tools
Similar Threads for: HP50G Quick Question...
Thread Forum Replies
Need a more powerful calculator (beyond ti-89T, hp50g) Calculators 1
HP50g or TI-89 Titanium Calculators 5
Help with HP50G Calculators 9
TI-89 or HP50g Calculators 1
HP50g statistical General Math 5
