Why Are Coherent States Essential for Measurement in Loop Quantum Gravity?
  • Context: Graduate
  • Thread starter Thread starter sheaf
    Lqg Measurements
The discussion centers on the role of coherent states in Loop Quantum Gravity (LQG) and their significance for measurement processes. Participants explore the implications of spin networks, volume operators, and the emergence of classical spacetime from quantum states, addressing both theoretical and conceptual aspects of LQG.
  • Some participants suggest that the quantum state of spacetime in LQG is represented by spin networks, with volume measurements corresponding to eigenvalues of volume operators.
  • There is a proposal that for a classical picture of spacetime to emerge, it must not be in a superposition, implying that measurements must occur.
  • One participant introduces the idea of defining regions for volume measurements in a covariant manner, potentially using physical objects or events.
  • Another participant mentions that the spin networks can symbolize volumes and areas, and that measuring these could reveal the geometry of the universe.
  • Some participants express uncertainty about the diffeomorphism invariance of volume and area operators, with differing views on their observability depending on the context of gauge fixing.
  • There is a discussion about the relationship between coherent states and classical geometry, with one participant noting a lack of understanding regarding the necessity of coherent states in LQG.
  • Several references to literature and resources are provided for further exploration of LQG concepts, including works by Rovelli and others.
Participants express differing views on the nature of volume and area operators in relation to diffeomorphism invariance, and there is no consensus on the necessity or role of coherent states in the measurement process within LQG.
Some claims about the properties of volume and area operators depend on specific definitions and contexts, and the discussion includes unresolved questions about the implications of gauge invariance and the nature of measurements in LQG.
This discussion may be of interest to those studying Loop Quantum Gravity, quantum measurement processes, and the relationship between quantum states and classical geometry.
sheaf
I’ve been starting to look at how LQG works, and if I’ve understood it correctly, just thinking about the kinematics, the quantum state of spacetime is encoded in a spin network. If I want to determine the volume of a region of spacetime, the result will be an eigenvalue of some volume operator. For a classical picture of spacetime to emerge, where a region of spacetime has a well defined volume, isn’t it the case that spacetime must no longer be in a superposition, i.e. “measurements must have happened” ? Is there any agreed way that people heuristically think about the measurement process ?
Consider a box with atoms. Each atom has a discrete spectrum of energy levels, and exists in a superposition of those, but the total energy in the box is, in some sense, "well defined".
sheaf said:
... Is there any agreed way that people heuristically think about the measurement process ?
The spin networks are the eigenvectors of area and volume operators. The labels on the network determine a certain amount of volume for each node and a certain amount of area assigned to each link.
In order to have a meaningful measurement of volume there must be some physically defined region. Heuristically, think of a region defined in some covariant way, by a physical object or some definite events. Then there is an associated volume observable.
In the state specified by a particular spin network, the volume is just the sum of all the volumes belonging to the nodes of the network which are inside the volume. (I duck the question of borderline cases.)
Or there is some physically defined surface---a desktop?!, an horizon of some type?---and you look at the set of all the links in the network which are CUT by this surface, and add up all the area numbers which are associated with those cut links.
John Baez might have a "This Week's Finds" about this from some years back. He's good with heuristics. Or Rovelli if you find something of his written for beginners, where he wants to make it intuitive.
The nodes of the network can symbolize chunks of volume (that could be revealed by measurement) and the links can stand for flakes of area bounding the chunks. Intuitively if you specify all the possible areas and volumes that you could measure, then you have somehow determined the geometry of the universe. The state of geometry of the universe is somehow revealable by taking all possible area and volume measurements.
I guess there could be other combinations of different sorts of geometric measurements that would also determine a geometric state. There could be some other basis for the kinematic Hilbertspace. Eigenvectors of some other types of geometric measurement.
I'm not a loop gravity expert, but you asked for some heuristic and I can offer a bit of personal intuition. Have you tried Rovelli's book, an online draft is available free for download, or any of the various introductory articles. What level are you trying to go in at?
Afaik neither volume nor area operator are diff.-inv. observables in LQG.
I must be wrong then! You are definitely more knowledgeable than I! I will leave my post uncorrected so that the questioner can see what i was trying to say, even if it was in error.
Can you offer an improved version of the heuristics?
I don't want to argue, I'll take your word on it. Should we say whether the spin networks are embedded or combinatorial ones (there are those two approaches)? I was thinking that in order to have some definite particular area (or volume) operator there must be some definite physical object. If you then want to talk about diffeo-invariance then if you re-coordinatize the space then the physical object gets re-coordinatized along with everything else.
That depends on how you look at it. If you want a volume operator that gives you a 3-volume of a region that's bounded by points with specific 4-coordinates, then of course it's not a diffeomorphism invariant observable, in ANY theory. If you fix the gauge by factoring out diffeomorphisms, what remains is perfectly observable.
Concerning gauge invariance, my understanding is that area and volume operators defined at the kinematical level are in fact invariant under 3-diffeomorphisms. Of course, physical obversables, as with quantum states, have to be invariant under the full gauge symmetry and therefore are the subset of the kinematical part that also satisfy the Hamiltonian constraint.
Thanks everyone, I guess where I'm coming from is I'm trying to see, given the tiny amount I know about LQG, how classical GR arises in some limiting case. Given that in GR volumes of regions are well defined, I was trying to understand how that would arise given that the universe may not be in an eignestate of the volume operators. But maybe what Hamster said is the right way to look at it - i.e. as an ensemble.
I'll definitely take a look at the Rovelli online draft though - I wasn't aware that was available.
Google "rovelli" to get the website. Google "rovelli book" to get the link to PDF
www.cpt.univ-mrs.fr/~rovelli/book.pdf
Hanno Sahlmann has a recent (2010) introduction to LQG on arxiv.
There is a 1998 introduction by Rovelli and Upadhya on arxiv.
I might think of other stuff, you just have to sample and find what's right. Maybe Orbb, Hamster, Tom have some recommendations.
Just in case they might be helpful, Rovelli's 2008 review article:
http://relativity.livingreviews.org/Articles/lrr-2008-5/
and a video of the introductory talk he was invited to give at the Strings 2008 conference:
http://cdsweb.cern.ch/record/1121957?ln=en
the slides for that talk are also available separately at the cern website:
http://indico.cern.ch/getFile.py/access?contribId=30&resId=0&materialId=slides&confId=21917
The most common approach in LQG to try to get classical geometry is to use a coherent state. There's a reader friendly write up in the last section of http://arxiv.org/abs/1007.0402 .
I have never understood why things are supposed to be in coherent states.
  • · Replies 26 ·
  • · Replies 0 ·
