| New Reply |
A proposed Hamiltonian operator for Riemann Hypothesis |
Share Thread | Thread Tools |
| Jul20-10, 07:01 AM | #1 |
HERE http://vixra.org/pdf/1007.0005v1.pdf
is my proposed proof of an operator whose Eigenvalues would be the Imaginary part of the zeros for the Riemann Hypothesis the ideas are the following * for semiclassical WKB evaluation of energies the number of levels N(E) is related to the integral of pdq along the classical orbits * for one dimensional systems, in the WKB approach the inverse of the potential V(x) is proportional to the Half-derivative of N(E) * For the case of Riemann Zeros the N(E) is given by the argument of Riemann Xi fucntion Xi(s)= s(s-1)G(s)Z(s) G=gamma function Z= zeta function evaluated on the critical line [tex] Arg\xi(1/2+iE) [/tex] If we combine these points then the inverse of the potential V(x) inside the Hamiltonian H=p^2 +V(x) would be proportional to the HALF INTEGRAL of the logarithmic derivative of [tex] \xi(1/2+iE) [/tex] as i express in the attached .PDF see formulae 3 4 and 5 inside the paper Also as a final NUMERICAL test, i think that the functional determinant of this operator [tex] H=p^2 +V(x) [/tex] is related to the Xi function, since the Hadamard product applied to Xi function can be used to express the Xi function as a product of the eigenvalues of some operator in brief, the INVERSE function of the potential V(x) is given by the half-integral of the logarithmic derivative of the Xi function evaluated on the critical line 1/2+is also the FUNCTIONAL DETERMINANT of the operator [tex] H+m^2 [/tex]is the Riemann Xi-function |
| Jul20-10, 07:24 AM | #2 |
Why cast everything in terms of physics terminology? If you really do have a proof then you should be able to translate it into purely mathematics terminology which would be much better. The Riemann Hypothesis is, after all, a mathematics problem, not physics.
| Jul20-10, 07:49 AM | #3 |
HAMILTONIAN : linear differential operator of the form [tex] H=-y''(x)+f(x)y(x) [/tex] the boundary condition imposed in general are that the solution is on an [tex] L^{2} (R) [/tex] space ENERGIES = eigenvalues of the operator [tex] f^{-1}(x)= A \frac{d^{-1/2}g(x)}{dx^{-1/2}} [/tex] is valid ONLY for one dimensional system and is am asymptotic approximation , in the same way the Prime counting function is asymptotic to x/lnx [tex] g(x)= \sum_{n} \delta (E-E_{n}) [/tex] dirac delta distributions over the eigenvalues of the operator H for our case [tex] g(x)= \frac{dArg\xi(1/2+ix)}{\pi dx} [/tex] the inverse of f(x) is NOT exact is valid as an ASYMPTOTIC formula , |
| Jul20-10, 09:25 AM | #4 |
Recognitions:
| Jul20-10, 10:49 AM | #5 |
umm sorry in physics is used to write = even for asymptotic, i think this would be better
[tex] f^{-1} (x)\sim 2\sqrt \pi \frac{d^{-1/2}g(x)}{dx^{-1/2}} [/tex] in physics one use this approximation we approximate a sum over eigenvalues , for a double integral in (p,q) for example [tex] \sum_{n}^{\infty}e^{iuE_{n}} \approx \iint_{R^{2}} dpdqe^{iup^{2}+iuV(q)} [/tex] p is the momentum and q is the position |
| Jul21-10, 03:37 PM | #6 |
So what is happening is that your phyics notation is leading you in to inaccuracies. I was afraid of that. How are you going to go from you approximation, or asymptotic limit, to an exact value?
| Jul21-10, 10:38 PM | #7 |
Do you believe that you have found the relevant [itex]V(x)[/itex], or that you have only proven its existence?
| Jul22-10, 03:56 AM | #8 |
Harmonic Oscillator [tex] f= (wx)^{2}/4 [/tex] the result is EXACT POtential well [tex] f=0 [/tex] then i get the approximate value [tex] 2/\pi [/tex] i have not 'invented' my formula is just a consequence of the approximate formula used in WKB semiclassical quantum mechanics [tex] \pi n(E) \approx 2\int_{a}^{b}dx (E-V(x))^{1/2} [/tex] http://en.wikipedia.org/wiki/WKB_method http://en.wikipedia.org/wiki/Bohr%E2...merfeld_theory (see section: one dimensional potential) here N(E) means how many energy levels are there with energy less than a given E for the Riemann Zeros considered as Energy levels then [tex] \pi n(E)=Arg\xi(1/2+iE) [/tex] |
| Jul31-10, 07:36 AM | #9 |
http://en.wikipedia.org/wiki/WKB http://en.wikipedia.org/wiki/Old_quantum_theory i really do not understand mathematician, an approximate result does not mean that it is NOT valid , i guess that if you calculate the energies of my operator you will obtain the imaginary part of the zeros |
| Aug1-10, 04:06 AM | #10 |
Either you have a definition for the [itex]V(x)[/itex], or then you don't.
If you have the definition, you can write it here for others to see. If you cannot write it here for others to see, then you don't have the definition. It is amazing that you have deceived yourself into believing that you have the definition, even though you have no idea about what the definition could be, and have never even seen it. |
| Aug1-10, 07:27 AM | #11 |
[tex] \sqrt \pi V^{-1} (x) = \frac{1}{\sqrt i} \frac{d^{-1/2}}{dx^{-1/2}}\frac{ \xi ' (1/2+ix)}{\xi (1/2+ix)}+ \frac{1}{\sqrt -i} \frac{d^{-1/2}}{dx^{-1/2}}\frac{ \xi ' (1/2-ix)}{\xi (1/2-ix)} [/tex] [tex] \frac{d^{-1/2}f(x)}{dx^{-1/2}}= \frac{1}{\sqrt \pi} \int_{0}^{x} dt \frac{f(t)}{(x-t)^{1/2}} [/tex] this definition for the INVERSE of the potential is obtained by solving a non-linear integral equation defining the number of Zeros n(E) and the potential in the semiclassical approximation [tex] n(E)= A\int_{0}^{E}dx (E-V(x))^{1/2}= \frac{1}{\pi}Arg\xi(1/2+iE) [/tex] |
| Aug1-10, 08:42 AM | #12 |
| Aug8-10, 09:03 AM | #13 |
i have checked the first 3 eigenvalues of my Hamiltonian and they satisfy
[tex]E_{0}= 13.1090 [/tex] , [tex]E_{1}= 20.1254 [/tex] , [tex]E_{2}= 30.0679 [/tex] using the semiclassical approximation http://en.wikipedia.org/wiki/WKB_approximation to solve the differential equation |
| Aug11-10, 12:24 AM | #14 |
Are those the imaginary parts of the first three non-trivial zeros of the Riemann Zeta function?
| Aug11-10, 03:29 AM | #15 |
The first few zeros have imaginary part 14.1347, 21.022, 25.0109, 30.4249, 32.9351, says Wolfram.
| Aug11-10, 03:32 AM | #16 |
i have used approximate methods to solve the Hamiltonian , this is perhaps why my zeros are not exact , perhaps a numerical evaluation or solution of Shchroedinguer equation will yield to more accurate evaluations
| Aug11-10, 04:14 AM | #17 |
I can't even tell what you claim to have proven.
| New Reply |
| Thread Tools | |
Similar Threads for: A proposed Hamiltonian operator for Riemann Hypothesis
| riemann hypothesis | Linear & Abstract Algebra | 17 | ||
| On Riemann Hypothesis | Linear & Abstract Algebra | 9 | ||
| Riemann Hypothesis | Calculus | 9 | ||
| the Riemann Hypothesis | Linear & Abstract Algebra | 15 | ||
| The Riemann Hypothesis | Calculus | 8 | ||
