Mathematical model for reducing mri noise
The discussion centers around the proposal for a mathematical model aimed at reducing acoustical noise in MRI systems. Participants explore the background knowledge required for this project, the causes of MRI noise, and the methodologies for analyzing recorded noise. The scope includes theoretical modeling, measurement techniques, and the application of various engineering principles.
  • Homework-related
  • One participant seeks guidance on how to create a mathematical model for reducing MRI noise and how to analyze recorded noise.
  • Another participant requests clarification on the original poster's background in MRI, electrical engineering, and mechanical engineering to provide more tailored advice.
  • The original poster indicates familiarity with mathematics, MRI techniques, and some signal analysis, but lacks knowledge in spectral analysis, time domain analysis, and mechanical properties relevant to noise.
  • The original poster outlines specific goals for the project, including studying the causes of acoustic noise, surveying existing models, measuring noise under different conditions, designing a model based on physical equations, and assessing the model through comparisons with measurements.
  • One participant expresses uncertainty about how to advise the original poster, suggesting that the request for a project plan may be beyond the forum's scope and recommending that the poster consult their thesis advisor for guidance.
Participants do not reach a consensus on how to proceed with the project. There is a divergence in expectations regarding the level of guidance that can be provided in an online forum setting.
Participants note limitations in the original poster's background knowledge, particularly in areas critical to the project such as spectral analysis and mechanical vibrations, which may affect the development of the proposed model.
landa110
dears
I study nuclear engineering (medical radiation ,MS) , my proposal for graduation is
(Modeling of Acoustical Noise in MRI and It Is Validation Through Measurements).
I want to make and deliver a mathematical model for reducing noise in mri,would you please tell me what should i do? and how can i make this model?and how can i analyse the noises which i have recorded by voice recorder?
thank you
Please give us some idea of your background. What do you know of MRI? Do you know the causes of the noise? How about electrical engineering, particularly material relating to signals and analysis. How much do you understand about spectral analysis? Time domain analysis? Finally how much mechanical engineering (vibrations, stiffness of materials, modes, sound propagation) is in your background? This will help us guide you.
Thank you for your reply
My base is applying mathematics and I know about MRI technics , I know about electromagnetic and mechanics , I know about signals and analysis by mathlab
Software, but I do not know anything about spectral analysis and Time domain analysis and vibrations, stiffness of materials, modes, sound propagation.
But in this project I want to deliver a mathematical model theorycaly and answer the following questions.
1- study and survey about causes of Acoustic Noise in MRI.
2- study and survey about models which related to AN(Acoustic Noise).
3- measurement of AN in different conditions MRI technics.
4- designing model according physical and electromechanical equations in MRI
technics.
5- assessment of model, according camparison of conclusion by Measurement
amounts.
Thank you
Your background as stated seems sound, so I'm uncertain how to advise you. Your questions:
thank you
essentially are asking for someone to plan your project for you, lay out the analysis, and tell you exactly how to perform the work. Planning someone's MS thesis project is a little out of scope for an online help forum.
Please don't take this the wrong way if I'm off base, but my thought right now is that you might look at choosing a different project that's a better fit to your areas of expertise. As a test of appropriateness, you should have some idea of how to get started, what kinds of analysis are required (at least in general), and what's needed to complete the project--on your own. Your thesis advisor should be helpful as well.
I think that we at PF are better suited to answering a specific technical question that arises during your work, as opposed to acting as a general thesis advisor. Perhaps someone else here has a different perspective, however...
  • · Replies 191 ·
14K
9K
  • · Replies 64 ·
