Calculating force with only mass and distance known
  • Context: Undergrad
  • Thread starter Thread starter GMCOWNER
    Force Mass
The discussion centers around calculating the force applied to a block given its mass and the distance it travels, without knowing the acceleration. Participants explore the information needed to perform this calculation and clarify the scenario presented.
  • Exploratory, Technical explanation, Debate/contested, Homework-related
  • One participant states that there is not enough information to calculate the force.
  • Another participant asks for clarification on what additional information is needed to proceed with the calculation.
  • A further contribution seeks to clarify the scenario by asking for details about how the block is set on a peg and how pressure is applied, questioning the terminology used.
  • Participants express the need for a detailed explanation or a proper drawing of the experiment to provide meaningful assistance.
Participants generally agree that the information provided is insufficient to calculate the force, but there is no consensus on what specific additional information is required or how to interpret the scenario.
Limitations include ambiguity in the description of the experimental setup, the use of the term "pressure" versus "force," and the lack of details regarding the direction of movement.
GMCOWNER
Say I have a block with a known mass and surface area. If I apply an unknown force to the block and it travels a known distance how can I calculate the applied force. It seems simple if I had a known acceleration but I do not.
PLEASE HELP!
You simply do not have enough information.
What other information would i need?
As AJ said not enough information is given. is this a example, if so can you type it up, or up load it?
Basically i have a block that is set on a peg 3.5" off of the ground. We apply a unknown pressure to it and see how far it travels. I need to find out what the force applied to the block is. How can i calculate this. If i do not have enough info what other info do i need?
It still isn't clear what you mean.
'Set on a peg' could mean anyone of a number of scenarios.
How are you applying pressure? Do you know what exactly the word pressure actually means in physics? Or do you mean a force?
'See how far it travels' - In which direction, up? down? sideways?
You will need to explain in careful detail exactly what your experiment looks like if we are to help you. A proper drawing would be helpful (Not some hasty scribble - do it carefully).
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 51 ·
11K
  • · Replies 16 ·
