Converting A Polar Equation to Rectangular Form; Equation of a Circle
The problem involves converting a polar equation, specifically r = 2(h cos θ + k sin θ), into rectangular form and verifying that it represents the equation of a circle. The task also includes finding the radius and the rectangular coordinates of the circle's center.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss multiplying both sides of the polar equation by r and applying the relationships x = r cos θ and y = r sin θ. There is uncertainty about the next steps after reaching the equation x^2 + y^2 = 2(hx + ky). Some participants suggest separating terms and completing the square.
Participants are actively engaging with the problem, exploring different approaches to complete the square and questioning how to manipulate the equation to achieve the desired form. There is a focus on understanding the necessary steps to derive the equation of a circle from the given polar equation.
There is an emphasis on ensuring all steps are clear and accounted for, particularly in the process of completing the square. Participants are encouraged to consider what needs to be added to both sides of the equation during this process.
themadhatter1
Convert the polar equation
to rectangular form and verify that it is the equation of a circle. Find the radius and the rectangular coordinates of the center of the circle.
First, I multiply both sides by r and distribute.
[tex]r^2=2hr\cos\theta+2kr\sin\theta[/tex]
apply the x= r cos θ and y= r sin θ equations
[tex]r^2=2hx+2ky[/tex]
from here I can factor out the 2 and plug it into the equation for a circle.
[tex]x^2+y^2=2(hx+ky)[/tex]
not quite sure what do do from here.
The answer to the problem is supposed to be:
[tex](x-h)^2+(y-k)^2=h^2+k^2; \sqrt{h^2+k^2}; (h,k)[/tex]
So far, so good. Separate the terms on the right, and bring them over to the left. Then complete the squares in the x and y terms.
Hmm. Ok, I think I know what you mean.
[tex] x^2+y^2=2hx+2ky[/tex]
bring it over to the other side and complete the square and you get
[tex](x-h)^2+(y-k)^2=0[/tex]
How would you get the [tex]h^2+k^2[/tex] on the RHS of the equation?
You're skipping the steps that would produce what you're looking for.
x2+y2=2hx+2ky
==> x2 - 2hx +y2 - 2ky = 0
Now, when you complete the squares in the x and y terms what do you need to add? You'll need to add the same amount on the right side.
If it still isn't obvious what you need to add on each side of your equation, simply expand some squares to gain some insight.
What about,
[tex](x+2)^{2} = x^{2} + 4x + 4[/tex]
or,
[tex](x + 8)^{2} = x^{2} + 16x + 64[/tex]
So now,
[tex]x^{2} - 2hx + ?[/tex]
What do you need to add (maybe in terms of h :wink:) in order to complete the square?
  • · Replies 16 ·
