How can I optimize a function on a non-linear set with unknown points?
  • Context: Graduate
  • Thread starter Thread starter Kreizhn
    Minimization Sets
This discussion focuses on optimizing a function in quantum mechanics, specifically minimizing the norm of points in a non-linear set defined by the function f: ℝⁿ → ℝ, where S = f⁻¹(0). The user is exploring constrained discrete simulated annealing and level set optimization as potential numerical algorithms for this problem. Key characteristics of the function include continuity, smoothness, and oscillatory behavior, with the derivative potentially being bounded but difficult to demonstrate. The goal is to find an effective algorithm to minimize the norm without knowing the locations of all points in S.
  • Understanding of quantum mechanics and optimal control theory
  • Familiarity with numerical algorithms, specifically constrained discrete simulated annealing
  • Knowledge of level set optimization techniques
  • Basic concepts of continuity and differentiability in mathematical functions
  • Research "constrained discrete simulated annealing" for optimization techniques
  • Explore "level set optimization" and its applications in non-linear problems
  • Study "combinatorial optimization" methods for finite sets
  • Investigate the properties of "oscillatory functions" and their impact on optimization
Researchers in quantum mechanics, mathematicians focused on optimization problems, and practitioners developing numerical algorithms for complex functions.
Kreizhn
Hey all,
I'm doing some research on computing optimal controls in quantum mechanics, and need a numerical algorithm that I can try to adapt to my problem. I'm hoping that if I describe the problem, someone out there can point me in a good direction.
Consider a function [itex]f: \mathbb R^n \to \mathbb R[/itex] and let [itex]S=f^{-1}(0)[/itex]. I want to find
[tex]\min_{\vec x \in S} \| x \|_2[/tex]
While we do not have any theoretical results of yet proving this, we empirically believe that S is countable and hence totally disconnected. Furthermore, within a finite radius of the origin, we believe that S is actually finite (and hence this could be seen as a combinatorial optimization problem).
Now I can find a single point in S, but the goal is to minimize the norm without knowing where the other points in S lie. I've been looking into constrained discrete simulated annealing and superficially at level set optimization, but I'm not sure if there's a better way. If anyone knows of an algorithm that is designed to handle this (or something similar) it would be much appreciated.
Mathematics news on Phys.org
The qualitative properties of f matter a lot; there's pretty much nothing you can do when f is a completely arbitrary function.
e.g. Is f smooth? Piecewise smooth? Does it have a bounded derivative?
Sorry, should have included that. The problem is that the function doesn't just depend on x. It depends on many other things that are also allowed to vary (even the dimension of the domain). For our purposes we can hold those other things constant, but they tend to change the qualitative properties a lot making it hard to stipulate general characteristics.
In general the function is only continuous, and S actually represents all points where the gradient is not defined. Hence the derivative is not bounded.
However, we do not think f ever actually attains a value in S, but rather just comes arbitrarily close in infimum. The derivative is still not bounded but the function in this case is smooth. This is fine since numerically, we can only operate to within machine precision and in fact, we are satisfied with approximations far less accurate than that. That is, for [itex]\epsilon>0[/itex] sufficiently small we can take [itex]S = f^{-1}(\epsilon)[/itex]. This set would have non-zero measure by continuity, but then quotient out connected components to make this a discrete problem again.
I hope that helps a bit. In general, assume that
f is bounded above and below (by zero)
f is smooth
[STRIKE]f does not have bounded derivative.[/STRIKE]
f is highly oscillatory (making local extrema populous)
f is "sharply peaked" around extrema
Edit: Actually, the derivative might be bounded, but this would be a very hard result to show. I'll have to think about it a bit more.
