Help me find the range of an equation please
  • Thread starter Thread starter GreenPrint
    Range
The discussion revolves around finding the range of the function y = (x^2 - 4)/(x^2 - x - 12), which involves calculus concepts such as derivatives and critical points. Participants are exploring the behavior of the function and its extrema.
  • Participants discuss finding the derivative of the function and setting the numerator to zero to identify critical points. There is confusion about the number of critical points and the behavior of the function in different quadrants.
The conversation is ongoing, with some participants questioning the correctness of their derivatives and the existence of critical points. Guidance has been offered regarding the interpretation of the graph and the identification of critical values, although there is no explicit consensus on the total number of critical points.
Participants are navigating potential errors in differentiation and the implications for identifying critical points. There is mention of vertical asymptotes and the need to clarify the behavior of the function around these points.
GreenPrint
FIXED :)
y = (x^2 -4)/(x^2 - x -12)
dy/dx of numerator I got 2x
dy/dx of denomenator I got 2x - 1
dy/dx of y I got -(x^2 - 16x -4)/((x-4)^2(x+3)^2)
setting numerator to zero and solving got 8 +/- sqrt(65) with the critical value being the +
setting denomenator to zero and solving got 4 and -3 which are both out of range of the original function...
so now what how do I find the range kind of confused... found one critical value how do I find the others kind of lost here thanks
Don't you already have a thread with the exact same question in the precalculus section?
Yes then I realized after reading comments that it shouldn't be in there becaue it's now calculus stuff... can you help me?
That's not a good reason to post the same topic in another section.
Fixed error in thsi post as well ok :)
I'm tyring to find the range of the following equation
(x^2 - 4)/(x^2 - x -12)
In order to do so I have found the derivative
-(x^2 + 16x + 4)/(x^2-x-12)^2
setting the numerator to zero and solving yields to extrema 2(4 +/- sqrt(15)) the only probelm I have is that a quick check of the graph shows me that there are three how do I find the other one that I can't get... it's the one in the fourth quardrant whose line appears only in the first quadrant, yes I know it's all one line, on the graph, i.e. not the one in the first or the one in all four...
pleaes show me how to do this or tell me thanks
You didn't differentiate the function correctly. Is the denominator correct? It seems a bit strange to have two linear terms, and I don't see how you got the denominator of the derivative from the denominator of the original function.EDIT: Never mind. I see you have a different function in the original post of this thread. The derivative is close but doesn't quite match what Mathematica gives, so check your algebra. The quadratic term in the numerator should be negative.
Yes I believe it's correct the quotient rule says that the denomenator of the derivative is the denomenator squared of the original funciton... no? I thought so I don't know I must be doing something wrong can't figure it out
http://en.wikipedia.org/wiki/Quotient_rule
see but you I must be doing something wrong don't see what the numeraotr I believe gave me two correct ones just don't know how to find the third critical value don't see what I am doing wrong
It does see
it's right infront...
oh crap your right hold up
it's suppose to be 12 let me see I still don't see how your suppose to get 3 critical points
I still get this as a derivative
-(x^2 + 16x + 4)/(x^2 - x - 12)^2
critical values are 2(-4 +/- sqrt(15) )
still need a third one
It's the same :O
That's correct. In your first post, however, you wrote
GreenPrint said:
dy/dx of y I got (x^2 - 16x -4)/((x-4)^2(x+3)^2)
which is slightly different. It's missing negative sign on the quadratic term.
Ok I'm sorry please forgive me but I still don't know how to find the third value and don't see how to setting the denominator to zero only yields the vertical asymptotes I need the third critical value in the foruth quardrant of the graph how do I find this
Why do you think there's a third critical point?
Inspect the graph there is one on the left side after it crosses and yes passes through y=1 it drops down and then goes back up in the fourht quadrant no?
Yes, there's one there, and there's one in the middle section between the two vertical asymptotes. Those are the only two as far as I can see, and they correspond to the two roots you found.
ok but put in 2(-4 + sqrt(15)) you get the point in the middile
put in 2(-4 - sqrt(15)) you get the point on the left sorry
so then how do I get the point on the right?
There is no critical point on the right.
There isn't one huh? All of this time I thought I had done something wrong... THANKS A MILLION!
ok makes sense I feel very stupid thank you!
  • · Replies 25 ·
  • · Replies 105 ·
13K
