What is the pattern for finding the last two digits of 16 to a power?
  • Thread starter Thread starter thereddevils
The discussion revolves around finding the last two digits of the expression 16^198, which falls under the subject area of modular arithmetic and number theory.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore patterns in the last two digits of powers of 16, noting a repetition every four terms. Some question the accuracy of their calculations and the implications of using approximations from calculators. Others suggest using modular arithmetic to simplify the problem.
The discussion is active, with participants sharing various methods and insights. Some have offered guidance on focusing only on the last two digits during calculations, while others are exploring the implications of their findings and questioning their assumptions about the calculations.
Participants mention limitations of calculators in determining last two digits and express uncertainty about modular arithmetic, indicating a need for clarification on these concepts.
thereddevils
What are the last two digits of 16^198
I begin by looking for a pattern.
16^2 = 256
16^4 = ...36
16^6 = ...16
16^8 = ...96
16^10 = ...56
so i see that the pattern repeats itself every 4 times. Then, i grouped the power as follows,
(2,4,6,8) , (10,12,14,16) , (18,20,22,24) , ... , (194,196,198,200)
The last number of each group has formula of 8n and that's how i got the last group.
198 is third in the group which corresponds to the number having 16 as its last two digits.
But i think i went wrong somewhere because the answer given is 96. Am i totally off track?
You missed one.
1610=1099511627776
It's 1612 that ends in 56.
vela said:
You missed one.
1610=1099511627776
Thanks Vela, i am using a 570 calculator and it gives 1.099511628 x 10^12 for 16^10 so how do i know its last two digits?
Just keep the last two digits in your calculations. The higher order digits don't matter.
yes, i know. The problem is how do i know the last two digits from 1.099511628 x 10^12. It looks to be 00. That's the maximum degree of accuracy my calculator can measure to.
Think about this... u'd get the last two digits of 16^198 as a remainder if u divide it by 100. Correct?
So, u have to find 16^198 (mod 100). To do this you can use, general theorem
a*b (mod c) = a(mod c) * b(mod c).
if you want to use ur calculator for solving this, but can't because of limitations in accuracy, here is what u can do.
16^10 = 1.099511628... X 10^12 is clearly an approximation. To find the last two digits, subtract from this approximate number the exact number 1.099511628 X 10^24. This will give you the remaining digits of the answer. If that is too long again, repeat. Finally, you should get the last two digits.
However, I suggest the method given above by me. It is easier.
thanks i figured out another way of getting the last two digits.
Btw, i am not familiar with modular arithmetic but will pick up very soon.
You can toss any higher digits even on intermediate calculations.
162 = 256 ⇒ 56
164 ⇒ 56*56 = 3136 ⇒ 36
166 ⇒ 56*36 = 2016 ⇒ 16
168 ⇒ 56*16 = 896 ⇒ 96
1610 ⇒ 56*96 = 5376 ⇒ 76
1612 ⇒ 56*76 = 4256 ⇒ 56
Even if you don't know modular arithmetic, this should make sense to you. Any digit in the 100s position or higher can only contribute some multiple of 100 to the product, so it won't affect the two least significant digits. For example, consider 256*256. We can write
2562=(200+56)(200+56) = 2002 + 2(200)(56) + 562
The first two terms will be some multiple of 200, so their bottom two digits have to be zero. Only the last term, 56*56, contributes to the two lowest-order digits.
162 = 256 ⇒ 56
yeah thanks, i figured that out.
