Solving a Rotating System with Point Mass
The discussion focuses on solving a physics problem involving a rotating disk with a point mass oscillating around its center. The key approach involves using the conservation of angular momentum to derive an equation that calculates the mass ratio between the disk and the point mass based on angular velocity changes over time. The moment of inertia for the point mass is defined as I=mr², and two extreme cases are considered: when the mass is at the center and when it is at the edge of the disk. The proposed method is validated by peers in the discussion.
  • Understanding of angular momentum conservation principles
  • Familiarity with moment of inertia calculations
  • Basic knowledge of rotational dynamics
  • Ability to interpret and analyze graphical data
  • Study the conservation of angular momentum in rotating systems
  • Learn about moment of inertia for various shapes and configurations
  • Explore the dynamics of oscillating systems on rotating bodies
  • Research graphical analysis techniques for interpreting angular velocity data
Physics students, mechanical engineers, and anyone interested in rotational dynamics and oscillatory motion analysis.
Gavroy
Hey,
First, I want to say, if it is impossible for you to understand my text, which may be caused by the fact, that I do not speak english as my first language, please do not hesitate to ask me!
The problem definition is:
A disk with radius R rotates free in horizontal direction around its centre.
On the disk, there is a point mass m, which oscillates periodically around the centre of the disk. But the axis of oscillation from the point mass turns around the centre with the same velocity as the disk does.
The oscillation causes that the angular velocity of the disk changes with time.
Now, one should derive an equation which enables one to calculate the ratio of the masses (from the disk and the point mass) by using only data that can be worked out of a diagram which plots how the angular velocity changes with time.
I included two images which shows on the one hand the problem itself and on the other hand the diagram, we got to solve the problem.
I just want to know whether you think that my approach is legitimate.
I thought that one could use conversation of angular momentum in this case:
The moment of inertia of the point mass is:
I=mr2
I=mr2/2
Now I thought, I could say that I regard two "extreme cases"
1.) when the mass is at the centre of the disk
2.) when the mass is at the margin of the disk
Then I could use the maximum angular velocity and the minimum angular velocity w from the diagramm and calculate the ration of the masses by using the conservation of angular momentum by setting:
I(disk)*w max=I(disk)+I(point mass)*w min
cause in the first case the moment of inertia from the point mass is zero since the distance from the centre is zero.
and in the second the distance is equal to the radius from the disk.
Do you think my assumptions are all right?
Thanks for your help
(the diagram shows the angular velocity of the system varying by time )
I haven't seen any assumption in your calculation, but it's correct, I think :wink:
  • · Replies 45 ·
