Is the observable universe is spatially flat?
  • Context: Graduate
  • Thread starter Thread starter TrickyDicky
    Space
The discussion centers on the question of whether the observable universe is spatially flat, exploring various observational evidence and parameters related to this concept. Participants examine the implications of the parameter Ω and discuss different observational methods, including the Cosmic Microwave Background (CMB), Baryon Acoustic Oscillations (BAO), and Type Ia supernovae (SNIa), in the context of cosmological models.
  • Some participants mention that the parameter Ω, which relates to the total mass and energy of the universe, indicates a flat universe when Ω = 1.
  • Others argue that the estimates of Ω = 1 primarily derive from the CMB angular power spectrum, questioning what other observational evidence exists.
  • Participants propose that measuring distance and redshift to Type Ia supernovae allows tracking of the universe's expansion history, which fits with the assumption of Ω = 1.
  • Some participants contend that the flat model is assumed first, and observations of SNIa are fitted within that model, suggesting that these observations do not independently provide evidence of flatness.
  • One participant asserts that the universe is flat because Ω is 1, emphasizing that different values would imply a non-flat universe.
  • Another participant discusses the combination of CMB and BAO data as providing strong evidence for flatness, explaining that these measurements allow for the construction of large triangles across the universe to check for flatness.
  • Some participants highlight that while any two of the three (BAO, SNIa, CMB) can indicate flatness, combinations including CMB yield stronger constraints.
  • Concerns are raised about the degeneracy of supernova measurements with curvature, noting that intrinsic brightness is a free parameter in analyses, which complicates the interpretation of results.
  • It is mentioned that CMB alone does not constrain curvature significantly, but adding measurements of the nearby Hubble expansion rate can anchor CMB observations and provide tighter constraints on curvature.
Participants express multiple competing views regarding the evidence for a spatially flat universe, with no consensus reached on the sufficiency of different observational methods or the implications of the parameter Ω.
Limitations include the dependence on assumptions regarding the flat model, the potential degeneracy of measurements, and the unresolved nature of how different observational methods contribute to the understanding of spatial flatness.
TrickyDicky
Besides the power spectrum from the CMB, what other observational evidences suggest that our observable universe is spatially flat?
Thanks
Space news on Phys.org
There is a parameter Ω, which is related to the total mass + energy of the universe. A flat universe is given by Ω =1. Current estimates of baryonic matter + dark matter + dark energy add up to Ω = 1.
Yeah, but that estimates are mainly from the CMB angular power spectrum, my question was what other observational evidence is there?
By measuring distance and redshift to type Ia supernovae we can track expansion history. Since expansion depends on density we see that observations fit with omega=1.
I believe is the other way around, we assume a flat model first (later confirmed by CMB) and we fit the SN observations in that model, getting as a result an accelerated expansion that introduced a new parameter, dark energy. So the SNIa observations fit the model, they are not in itself evidence of flatness.
No, you got it wrong. It is flat because omega is 1. For some other value it will not be flat. In addition you can calculate it as (3c^2Ho^2)/8piG, and many measurments confirmed Hubble parametar to Ho=71 km/sec per mpc.
The best current evidence stems from the combination of CMB and BAO data.
The CMB sets a length scale of our universe at a redshift of [itex]z=1090[/itex]. Baryon Acoustic Oscillations, on the other hand, set a length scale of our universe around roughly [itex]z=1[/itex] to [itex]z=2[/itex]. This extremely long lever arm let's us do the equivalent of drawing a huge triangle across the universe, a triangle that we can then check the angles of and see if they add up to 180 degrees.
For illustration, see http://supernova.lbl.gov/Union/figures/Union2_Om-Ol_systematics_slide.pdf" . Any two of the three (BAO, SN,CMB) indicate flatness, but only combinations including CMB give strong constraints.
I should mention that the supernova measurements are almost completely degenerate with the curvature (this is because for supernovae, the curvature is almost completely degenerate with the intrinsic brightness, which is not very well-known and is fit as a free parameter for most SN data analysis computations). But they do constrain other cosmological parameters, in particular the ratio between matter density and dark energy density.
It's also worth mentioning that as you can see from that plot, CMB alone doesn't actually constrain curvature all that much. But all you need to do to get it to constrain curvature is add a measurement of the nearby Hubble expansion rate. This anchors the CMB observations, allowing curvature to be tightly constrained.
  • · Replies 54 ·
  • · Replies 93 ·
  • · Replies 25 ·
  • · Replies 37 ·
  • · Replies 17 ·
  • · Replies 44 ·
  • · Replies 26 ·
  • · Replies 39 ·
