How Does Electrode Separation Affect Spark Plug Efficiency?
  • Thread starter Thread starter rosely
The discussion focuses on the relationship between electrode separation and spark plug efficiency, specifically addressing a spark plug with a gap of 0.025 inches requiring a potential difference of 75,000 V to initiate a spark. Increasing the electrode separation decreases the required potential difference, as demonstrated by calculations for a 0.050-inch gap, which requires 150,000 V. Additionally, the discussion explores electric potential from point charges and the work needed to separate them, emphasizing the principles of electric fields and potential energy in electrical systems.
  • Understanding of electric fields and potential difference
  • Familiarity with Coulomb's law and electric potential calculations
  • Knowledge of capacitors and their properties
  • Basic principles of electrical energy storage
  • Study the relationship between electric field strength and potential difference in spark plugs
  • Learn about the calculations for electric potential in systems with multiple point charges
  • Explore the design and function of capacitors, including parallel-plate configurations
  • Investigate energy storage mechanisms in capacitors and their applications in electronic devices
Electrical engineers, automotive technicians, and students studying electromagnetism and electrical engineering principles will benefit from this discussion.
rosely
Electric Potential energy and the electric potential:
10) a spark plug in a car has electrodes separated by a gap of 0.025 in. To create a spark and ignite the air-fuel mixture in the engine, an electric field of 3.0 * 10^6 V/m is required in the gap.
a) what potential difference must be applied to the spark plug ti initiate a spark?
b) if the separation between electrodes is increased, does the required potential difference increase, decrease, or stay the same ? explain.
c) Find the potential difference for a separation of 0.050in.
Electric potential of point charges:
25) Point charges +4.1uC and -2.2uC are placed on the x-axis at (11m, 0) and (-11m, 0), respectively.
a) Sketch the electric potential on the x-axis for this system.
b) Your sketch shoul show onw point on the x-axis between the two charges where the potential vanishes. Is this point closer to the +4.1uC charge or closer to -2.2uC charge? Explain
c) Find the point referred to in part (b).
32) How much work must be done to move the three charges in figure 20-23 infinitely far from one another?
Equipotential Surfaces and the Electric Field;
36) two point charges are on the x-axis. Charge 1 is +q and is located at x=-1.0m, charge 2 is -2q and is located x=1.0m. Make sketchs of the equipotential surfaces for this system.
a) out to a distance of about 2.0m from the origin.
b) far from the origin. in each case, indicate the direction in which the potential increases.
Capacitors and Dielectrics
47) A parallel-plate capacitor has plates of area 3.45*10^ -4 m^2. What plate separetion is required if the capacitance is to be 1330 pF? Assume that the space between the plates if filled with
a) air
b) paper
Electrical Energy Storage
59) an electronic flash unit for a camera contains a capacitor with a capacitance of 850 uF. when the unit is fully charged and ready for operation the potential difference between the capacitor plates is 330 V.
a) what is the magnitude of the charge on each plates of the fully charged capacitor?
b) Find the energy stored in the " charged-up" flash unit.
thanks
Sure, I'd be happy to help you solve these problems. Let's go through them one by one:
10) a) To calculate the potential difference, we can use the formula V = Ed, where V is the potential difference, E is the electric field, and d is the distance between the electrodes. Plugging in the given values, we get V = (3.0 * 10^6 V/m)(0.025 in) = 75,000 V. So, the potential difference required to initiate a spark is 75,000 V.
b) The required potential difference will decrease if the separation between electrodes is increased. This is because the electric field will be spread over a larger distance, resulting in a lower potential difference. This can also be seen from the formula V = Ed - as d increases, V decreases.
c) Using the same formula, we can calculate the potential difference for a separation of 0.050 in: V = (3.0 * 10^6 V/m)(0.050 in) = 150,000 V.
25) a) The electric potential on the x-axis can be calculated using the formula V = kQ/r, where V is the potential, k is the Coulomb's constant, Q is the charge, and r is the distance from the charge. On the left side of the x-axis, the potential will be negative due to the negative charge, and on the right side it will be positive due to the positive charge.
b) The point where the potential vanishes will be closer to the -2.2uC charge. This is because the negative charge will create a stronger electric field, and the potential will decrease faster as we move away from it.
c) To find the point, we can set the potential equal to 0 and solve for r: 0 = k(4.1 uC)/r - k(2.2 uC)/(11 - r). Solving for r, we get r = 11/3 = 3.67 m.
32) The work done to move the charges infinitely far from each other would be equal to the potential energy of the system. We can calculate this using the formula U = kq1q2/r, where U is the potential energy, k is the Coulomb's constant, q1 and q2 are the charges, and r is the distance between them. Plugging in the given values,
