Osmolarity Question: How to Prepare & Adjust 960mOsm?
  • Thread starter Thread starter indoubt
The discussion centers on preparing a solution with an osmolarity of 960 mOsm, specifically using 41g/L NaCl and a 10mM Hepes buffer at pH 8.2. Participants emphasize the importance of calculating osmolarity as the product of molarity and the number of ions per formula unit. To achieve the desired osmolarity, users must accurately measure the components and adjust concentrations accordingly. Understanding osmolarity is crucial for applications involving osmotic pressure and membrane diffusion.
  • Understanding of osmolarity and its calculation
  • Familiarity with molarity and normality concepts
  • Knowledge of buffer solutions, specifically Hepes buffer
  • Basic chemistry principles, including the gas equation and osmotic pressure
  • Learn how to calculate osmolarity using NaCl and other solutes
  • Research methods for adjusting osmolarity in solution preparations
  • Explore the role of osmotic pressure in biological systems
  • Study the properties and applications of Hepes buffer in biochemical experiments
Researchers, chemists, and biologists involved in solution preparation and osmotic studies will benefit from this discussion, particularly those working with osmolarity in laboratory settings.
indoubt
hello guys!
i am stucked at this one. i hope you can help me out. i have to make this solution;
41g/l NaCl
Hepes-buffer 10mM
Osm. 960 mOsm
pH8.2
i know how to prepare all the components, EXCEPT for 960mOsm. i wonder ;
1. how do i know that i have 960mOsm?
2. how to adjust the Osm, if the value is not correct.
and lastly, what is so important with mOsm?
thank you all for your time and sharing!
Chemistry news on Phys.org
Hello
I think this is also one of Biology's concerns, but let me contribute to the topic as a chemist.
I have no knowledge about osmolarity, but osmotic pressure is a known issue, easily calculated by a variation of the known gas equation, Pi*V=n*R*T, where Pi is osmotic pressure, V is volume, n is number of moles, R is a constant and T is the temperature.
However, we may speculate that osmolarity is the concentration of the compound undergoing osmosis, but calculation is the same though; Cosm=nosm/Vosm
I am sure you know this; osmotic pressure is caused by a membrane. So you are probably using a membrane and causing something to diffuse the other side from the membrane. Maybe this approach helps you a bit.
Regards,
chem_tr
Actually, osmolarity is calculated as the the product of the molarity and the number of ions in solution per formula unit of the molecule.
Sometimes, the normality is used instead of molarity - I'm not sure which is the standard convention.
9K
  • · Replies 18 ·
