What is the magnitude of the electric field inside the insulator
The magnitude of the electric field inside a long uniformly charged cylindrical insulator with a charge density of 1.1 micro-coulombs/m³ at a distance of 2.7 cm from the axis can be calculated using Gauss' law. By setting up a cylindrical Gaussian surface with radius less than R and applying the formula for electric flux, the electric field E can be expressed as E = (ρ * r) / (2 * ε₀), where ρ is the charge density and ε₀ is the permittivity of free space. Substituting the given values allows for the determination of the electric field in units of N/C.
  • Understanding of Gauss' law in electrostatics
  • Familiarity with cylindrical coordinate systems
  • Knowledge of electric field calculations
  • Basic concepts of charge density and permittivity
  • Study the application of Gauss' law in different geometries
  • Learn about electric fields in cylindrical coordinates
  • Explore the concept of charge density and its implications in electrostatics
  • Review the derivation and applications of the permittivity of free space (ε₀)
Students and professionals in physics, particularly those focusing on electromagnetism, electrical engineers, and anyone interested in understanding electric fields within charged insulators.
JamesL
Consider a long uniformly charged, cylindrical insulator of radius R with charge density 1.1 micro-coulombs/m^3. (The volume of a cylinder with radius r and length l is V = pi*r^2*l)
What is the magnitude of the electric field inside the insulator at a distance 2.7 cm from the axis (2.7 cm < R)? Answer in units of N/C.
The axis they are referring to in the problem runs through the cylinder from top to bottom...
i don't really know where to go with this problem. any pointers/tips/starting points would be great.
The electrical field from a single point charge q is the vector -qr/|r|3 where r is the vector from the charge to the point and |r| is the length of that vector. (The r in the numerator just gives the direction of the vector. The cube, rather than a square, in the denominator is to cancel the length of that vector.)
Set up a cylindrical coordinate system with origin at the center of one base and positive z-axis along the axis of the cylinder. The "differential of volume" in cylindrical coordinates is r dr d&theta;dz and the "differential of charge" is &rho;r drd&theta;dz where &rho; is the charge density.
Integrate -(&rho;r/|rho|3) rdrd&theta;dz (r is the vector from the given point (x,y,z) to the point in the cylinder and r is the distance from the origin to to the point in the cylinder) over the cylinder.
The simplest way to answer this is to use Gauss' law. Have you learned this?
Set up a cylindrical gaussian surface or radius r< R and length L (with its axis coincident with the axis of the real cylinder). The net flux through your gaussian surface will be the magnitude of the E field at a distance r times the surface area of the curved side of the gaussian surface, namely [itex]\Phi = E 2 \pi r L[/itex]. On the other hand, the net flux is also the total charged contained inside your gaussian surface divided by [itex]\epsilon_0[/itex], according to Gauss' law, i.e. [itex]\Phi = q_{in}/ \epsilon_0[/itex]. The charge contained inside your gaussian surface is [itex]q_{in} = \rho \times \pi r^2 L[/itex]. Now set the two expressions for the flux equal to one another (the length L of your gaussian surface will cancel out) and solve for E. Sub in the values for r (the 2.7 cm), [itex]\rho[/itex] and you're done.
Pat
  • · Replies 16 ·
