Verifying Equation for Particle Energy (E): p=γpmv
  • Context: Graduate
  • Thread starter Thread starter seto6
The discussion focuses on verifying the equation for particle energy, specifically the relationship between momentum (p) and relativistic factors (γ) in the context of special relativity. The correct expression for momentum is established as p = γmv, where γ is the Lorentz factor defined as γ = (1 - (v/c)²)^(-1/2). The kinetic energy (KE) is derived as KE = mc²(γ - 1), correcting the misconception that KE can be expressed as mv²/2. The relationship E² - (pc)² = E₀ is confirmed, establishing a foundational equation in relativistic physics.
  • Understanding of special relativity concepts, including Lorentz transformations.
  • Familiarity with the definitions of energy (E), momentum (p), and rest energy (E₀).
  • Knowledge of the Lorentz factor (γ) and its calculation.
  • Basic principles of kinetic energy in both classical and relativistic contexts.
  • Study the derivation of the Lorentz factor γ in detail.
  • Learn about the implications of relativistic momentum in high-speed particle physics.
  • Explore the full derivation of relativistic kinetic energy and its applications.
  • Investigate the relationship between energy, momentum, and mass in various physical scenarios.
Physics students, educators, and professionals in the field of particle physics or anyone interested in the principles of special relativity and energy-momentum relationships.
seto6
so we have total energy of particle ->E
p=γp=1/(1-(v/c)2)-1/2
1)E=γpmc2=E0+K=Rest energy+ kinetic energy
=mc2+mv2/2
the second line correct?
2) E2-(pc)2=E0
so P= mv or p=γpmv
im sure that we are suppose to use p=γpmv but not sure some one verify pls
I can't quite understand 2).
However for 1), if you expand p in a power series in (v/c)2, the first two terms are what you are showing. The higher order terms matter when v/c -> 1.
=mc2+mv2/2
Nope, the second line is not correct. mv2 is the Newtonian expression for kinetic energy (KE).
You can obtain the correct relativistic expression for KE from:
γ=(1-(v/c)2)-1/2
E=γmc2=E0+KE = Rest energy+ kinetic energy
KE = E-E0 = γmc2-mc2 = mc2(γ-1)
seto6 said:
2) E2-(pc)2=E0
so P= mv or p=γpmv
im sure that we are suppose to use p=γpmv so but not sure some one verify pls
You should be using p = γmv = mv(1-(v/c)2)-1/2 so that
E2-(pc)2=E02
E2=E02+(pc)2
E2=(mc2)2+(γmvc) 2
  • · Replies 26 ·
  • · Replies 131 ·
13K
  • · Replies 16 ·
  • · Replies 55 ·
