Solutions to a linear equation and perfect square
This discussion focuses on solving linear Diophantine equations and finding perfect squares using specific equations. The equation 3x + y = 394 is analyzed, demonstrating that integer solutions can be derived using the formula y = (c - ax) / b, where a, b, and c are integers. Additionally, the discussion explores the equation t = (81x^2) + (390240x) + 116964 to find the perfect square t = 115734564, with x = 280 being identified as the solution without exhaustive substitution. The importance of the greatest common divisor in determining the existence of integer solutions is also highlighted.
  • Understanding of linear Diophantine equations
  • Familiarity with perfect squares and their properties
  • Knowledge of algebraic manipulation and substitution methods
  • Basic concepts of number theory, particularly greatest common divisors
  • Study methods for solving linear Diophantine equations in depth
  • Explore algorithms for finding perfect squares efficiently
  • Learn about the properties of quadratic equations and their applications
  • Investigate the use of modular arithmetic in solving integer equations
Mathematicians, students studying algebra, and anyone interested in number theory and solving equations involving integers will benefit from this discussion.
smslca
1) Is there any way to find integer solutions for a linear equation ax+by=c, with a,b,c known and without having an another equation to substitute in the above one.
ex : 3x+y=394;
Is there any worst case for c being very large.
2)Is there any easy and fastest way to get t=115734564=9*(3586^2)
from t1=116964=9*(12996) to "t" using the equation t=(81*x*x)+(390240*x)+116964
Actually Here if we don't know the value of "t" and searching for a perfect square using the above equation. "t" is the first perfect square we ecounter at x, and all below x cannot generate a perfect square.
answer is t=280 , can we get "x" in the shortest way without substituting 1,2,3,...280 respectively.
i.e how to get from 12996 to a perfect square using the equation.
Mathematics news on Phys.org
If you have only the equation ax+ by= c then you can solve for y "in terms of x":
[tex]y= \frac{c- ax}{b}[/tex]\
Choose any value at all for x and calculate y from the formula.
If you also have the requirement that all numbers, a, b, c, and x and y are integers, this is a "Diophantine" equation. It will have no solution if the largest common divisor of a and b does not also divide c. If it does, then you can divide through by that common divisor so we can assume that a and b are relatively prime.
In the example you give, 3x+ y= 394, note that if x= 1, y= -2, then 3x+ y= 3(1)+ (-2)= 1. Further if we multiply those by 394, so that x= 394, y= -788, then 3x+ y= 3(394)+ (-788)= 394(3(1)+ (-2))= 394(1)= 394.
But, also, if we take x= 394- k and y= -788+ 3k, then 3x+ y= 3(394- k)+ (-788+ 3k)= 3(394)+ (-788()- 3k+ 3k= 3(394)+ (-788)= 394 again.
That is, x= 394- k and y= -788+ 3k, for k any integer, are integer solutions to 3x+ y= 394.
I don't understand what you are asking with "2)Is there any easy and fastest way to get t=115734564=9*(3586^2)
from t1=116964=9*(12996) to "t" using the equation t=(81*x*x)+(390240*x)+116964"
In what sense do you get t from t1?
u can see t1=116964 and t= (81x^2)+390240x+(t1)
So we have used t1 in t . i.e by adding something to t1 we get t.
also t1= 9*12996;
t = 9*(3568^2);
so by substituting x=280 in (81x^2)+390240x and adding it to t1 we get 12996 to 3568^2;
My question is : If we do not know the value of "t" and by substituting the integer values in
the equation of "t" , to search for a value of "t" which gives a perfect square, we will get it at x=280. So is there any fastest way(method) to say "x" value is 280 without substuting the whole integer values.
  • · Replies 23 ·
