Understanding and Applying Newton's Law of Cooling
The discussion centers on Newton's Law of Cooling, which states that the rate of temperature change of an object is proportional to the temperature difference between the object and its surroundings, expressed mathematically as \(\frac{dT}{dt} = -k(T - \hat{T})\). Participants demonstrated the derivation of the equation \(\frac{d\theta}{dt} = -k\theta\) and provided the general solution \(\theta(t) = Ce^{-kt}\). The calculations for specific values of \(\theta(3)\) were confirmed to yield 27, validating the approach taken by the participants.
  • Understanding of differential equations
  • Familiarity with exponential functions and logarithms
  • Knowledge of Newton's Law of Cooling
  • Basic algebraic manipulation skills
  • Study the derivation of solutions for first-order linear differential equations
  • Explore applications of Newton's Law of Cooling in real-world scenarios
  • Learn about the implications of temperature differentials in thermodynamics
  • Investigate numerical methods for solving differential equations
Students studying physics or mathematics, educators teaching thermodynamics, and professionals involved in heat transfer analysis will benefit from this discussion.
vorcil
Newton's law of cooling says that the rate at which the emperature of any object changes is proportional to the temperature difference between the object and its surroundings. So if the temperature of the object is T, and its surroundings are at a constant temperature [tex]\hat{T}[/tex]
[tex]\frac{dT}{dt} = -k(T - \hat{T})[/tex]
a) let [tex]\theta = T - \hat{T}[/tex], Show that [tex]\frac{d\theta}{dt} = -k\theta[/tex] and hence write down the general solution for [tex]\theta(t)[/tex]
b) given [tex]\theta(0) = 64[/tex] and [tex]\theta(2) = 36[/tex], find [tex]\theta(3)[/tex]
a)
[tex]\int \frac{d\theta}{dt} = \int -k\theta[/tex]
re arranging
[tex]\int \frac{d\theta}{\theta} = \int -k dt[/tex]
and integrating
[tex]ln(\theta) = -k t + C[/tex]
(I think I add a + C?)
exponentiating both sides
[tex]eln(\theta) = e^{-kt +c} = Ce^{-kt}[/tex]
though I'm not sure why the C goes out to the front, or why it is being multiplied by C
simplifying gives the solution
[tex]\theta(t) = Ce^{-kt}[/tex]
b)
[tex]\theta(0) = Ce^{-k * 0} = 64[/tex]
since [tex]e^{-k * 0} = e^0 = 1[/tex]
that makes
[tex]C*1 = 64[/tex]
so C = 64
now
so
[tex]64*e^{-k * 2} = 36[/tex]
[tex]e^{-k * 2} = \frac{36}{64}[/tex]
taking the logarithim of each side
[tex]-k*2 = ln(\frac{36}{64}[/tex]
solving for k, I get, K = 0.28768then going to [tex]\theta(3)[/tex]
putting it into the equation, then a calculator
64*e^{-0.28768*3} = 27
I think this is right, since it is a real number / integer, and it sort of fits the pattern
if someone could check, i'd be very happy, thank you :P
Firstly, you haven't answered the very first question.
Don't worry, when I was studying this, I did exactly the same thing and assumed I already had answered it. It's quite an arbitrary idea so you may need a little more practise here, because it's asked quite often on tests.
So you have the equations:
[tex] \frac{dT}{dt} = -k(T - \hat{T}) [/tex]
[tex]\theta=T-\hat{T}[/tex]
And you need to show that
Use the fact that [tex]\frac{d\theta}{dt}=\frac{d\theta}{dT}.\frac{dT}{dt}[/tex]
By a rule of exponentiation, [tex]a^{b+c}=a^ba^c[/tex]
so [tex]e^{-kt+c}=e^{-kt}e^c[/tex] but since c is just some constant we don't know yet, ec is also just some constant, so we simplify things and just give it another constant C (big c, don't use the same constant because [itex]c\neq e^c[/itex]).
Everything else is right, but if you aren't strapped for time in a test situation, then you may want to try a slightly more elegant approach to giving the final answer which will be an exact solution rather than relying on your calculator, for example, rather than:
You could do this,
[tex]-2k=ln\left(\frac{36}{64}\right)=ln\left(\frac{9}{16}\right)[/tex]
[tex]k=\frac{-1}{2}ln\left(\frac{9}{16}\right)[/tex]
[tex]=ln\left(\left(\frac{9}{16}\right)^{-1/2}\right)[/tex]
[tex]=ln\left(\left(\frac{16}{9}\right)^{1/2}\right)[/tex]
[tex]k=ln\left(\frac{4}{3}\right)[/tex]
then
[tex]\theta(3)=64e^{-3ln\left(\frac{4}{3}\right)}[/tex]
[tex]=64\left(e^{ln4-ln3}\right)^{-3}[/tex]
by using a combination of the rules [tex]ln\frac{a}{b}=lna-lnb[/tex] and [tex]e^{ab}=(e^a)^b[/tex]
[tex]=64\left(\frac{e^{ln4}}{e^{ln3}}\right)^{-3}[/tex]
[tex]=64\left(\frac{3}{4}\right)^3[/tex]
[tex]=64\left(\frac{27}{64}\right)[/tex]
[tex]\theta(3)=27[/tex]
There you have it, a confirmation that 27 is indeed the correct answer and your calculator isn't rounding off or anything.
Doing this in practise you'll of course be able to skip a lot of steps when you get more comfortable at doing it :smile:
good luck!
  • · Replies 25 ·
