Solving Motion & Speed Homework Problem with X, u and a
  • Thread starter Thread starter nirajnishad
    Motion Speed
The problem involves a stone being dropped from a balloon that is ascending at a uniform velocity. The goal is to determine the height of the stone when it hits the ground, given specific initial conditions and parameters such as initial velocity and acceleration due to gravity.
  • Participants discuss the method of using kinematic equations, with some questioning the signs of the quantities involved and the direction of motion. There are suggestions to consider the height of the balloon and the changing position over time. Some participants propose solving the problem using simultaneous equations.
The discussion is active, with participants providing guidance on the correct approach and emphasizing the importance of understanding the physical situation. There are multiple interpretations being explored regarding the timing and height of the balloon, as well as the method of solution.
Participants note the need to clarify the initial conditions, such as the height of the balloon and the direction of motion, which may affect the calculations. There is also mention of homework constraints that may limit the methods available for solving the problem.
nirajnishad
A stone is droped from a balloon going up with a uniform velocity of 5m/s.if the balloon was at 50m high when the stone was dropped, find its height when the stone hits the ground?
find the time for
X(distance)=-50m, u(initial velocity)=5m/s a(acceleration)=-10m/s*s
please show the the calculaion and methods to solve this problem
rather than this method
also if there is any other simpler way to solve this question?
i am not able to solve by using X=ut+1/2at*t
i tried the method shown in the book but i m not able to solve the above equation
That's the correct method
Make sure you got the signs correct for each quantity, pick a direction (ie up is +ve)
As a starting point, imagine if the rock was simply dropped - work out the time for that, then you know your answer should be a bit larger than this,
Take care of two things:
1. You have to find the height of the balloon.
2. Is the height of the balloon constant? NO! It changes with time. So, you have to find out the height of the balloon at some specific time! What is that time?
Now, I ask another question. What question needs to be solved first? 1 or 2?
For 2, all you have to do is use the s = ut + 0.5at^2
u = -5m/s, a = 10m/s^2, s = height of the balloon when the stone was thrown (+50 or -50?)
Find time.
Then for 1, there's no acceleration! So which equation will you use?
Another way to solve the question would be to setup equations for both the cases, with s1 and t1 as the unkowns.
Then solve them simultaneously through the methods learned in ninth standard!
Solve the question both ways in your notebook - simultaneously and sequentially!
Think about mgb_physics' suggestions.
He's giving you a physical picture. I gave you a way to get the answer - that's a technique. What he said is, our case will take longer time than the case where the rock would have been simply dropped.
Why's that so? Think about it, draw a simple diagram in which you contrast the two situations. Then tell me what you think!
IMP : SUCH SMALL INSIGHTS CAN BE VERY HELPFUL IN ELIMINATING OPTIONS IN OBJECTIVE QUESTIONS!
  • · Replies 19 ·
  • · Replies 24 ·
