| Thread Closed |
How do I calculate BTU? |
Share Thread |
| Aug5-10, 11:34 PM | #1 |
I have a gas water heater that has an exhaust of 475 degrees Fahrenheit. I would like to know, what formula can I use to determine the amount of BTU's that the water heater produces (or wastes) per hour of use. I only have the temperature of the exhaust (475 Deg. F) and the diameter of the flue which is 3". I would appreciate any help or guidance. Thank you.
| Aug8-10, 10:05 PM | #2 |
Mentor
You can't calculate it from the exhaust temp. But You can read your gas meter a couple of times when it us running. Or read it off the nameplate...
| Aug13-10, 06:43 AM | #3 |
You could do an experiment . A BTU is the amount of heat needed to raise one pound of water one degree F . You could place a glass jug of water near the exhaust and measure the temp increase . And of course measure the amount of water . Or you could
do it in calories , then convert to joules and then divide by the amount of time it took so this will give you power . At least this would give a crude approximation . |
| Aug18-10, 04:51 PM | #4 |
@ cragar: it is a great method to estimate the heater's power within three orders of magnitude.
@attitudeworks: it is impossible to tell using only this information. Can't you contact the company? |
| Thread Closed |
| Tags |
| btu, formula, heater, math, physics |
Similar discussions for: How do I calculate BTU?
| Calculate RPM | Introductory Physics Homework | 1 | ||
| How do I calculate this | Calculus & Beyond Homework | 1 | ||
| How do I calculate this on a TI-89? | Precalculus Mathematics Homework | 2 | ||
| How to calculate. | Calculus & Beyond Homework | 4 | ||
| Calculate e | Calculus | 10 | ||
