Subtracting Histograms: A Quick Guide
  • Thread starter Thread starter lavster
The discussion revolves around the process of subtracting histograms in ROOT/C++. Participants are seeking guidance on how to create a new histogram that represents the difference between two existing histograms.
  • Homework-related
  • One participant asks for help on how to subtract two histograms defined as pointers, h1 and h2, to create a third histogram.
  • Another participant inquires about the software being used, indicating the importance of context for the solution.
  • A participant clarifies that the software in use is ROOT/C++.
  • One suggestion involves making a copy or clone of the first histogram and using the Add method with a negative value for the second histogram to achieve the subtraction.
  • There is also a mention of normalization techniques related to histogram entries, suggesting the use of a Divide method for normalization.
Participants have not reached a consensus on the best approach to subtract histograms, and multiple methods are proposed without resolution.
There may be limitations related to the specific implementation details in ROOT/C++, and assumptions about the definitions of the histograms are not fully explored.
lavster
can anyone tell me how to subtract histograms?
ive got to histograms already defined (pointers) called h1 and h2. and i want to make a third histogram object that is one subtract the other.
so far I've got TH1F h3 = (*h2)-(*h1);
and then after defining a new canvas I've got
h3.Draw();
but its not doing anything :(
thanks!
Technology news on Phys.org
Which software are you using?
lol i forgot that bit - root/C++ :)
OK, I'll move this again to the "programming" forum...
I think you can do it by making a copy or clone of the first, A, and then using A->Add(B, -1), where B is your second histogram.
Likewise for normalization stuff in your other question, just use something like A->Divide(A->GetEntries), if that normalization function doesn't work.
11K
  • · Replies 19 ·
9K
