How can you prove this using only the ring axioms?
The problem involves proving a property of elements in a ring using only the ring axioms. Specifically, it addresses the expression aX(x-z) = (aXx) - (aXz), where a, x, and z are elements of a general ring (R, +, X).
  • Participants discuss the application of ring axioms, particularly focusing on the distributive laws and the concept of inverses. One participant attempts to manipulate the expression using the properties of addition and multiplication in a ring.
The discussion includes attempts to clarify the steps involved in the proof, with one participant expressing uncertainty about whether they have omitted important steps. Another participant provides a response that encourages further exploration of the properties of inverses in the context of the ring axioms.
There is a mention of potential confusion arising from the notation used for operations, as well as the importance of consistency in notation when discussing group operations within the context of ring theory.
dndod1
Using only the ring axioms, prove that in a general ring (R, +,X)
aX (x-z) = (aXx)- (aXz) where all a,x,z are elements of R
Group axiom 3: G3= There is an inverse for each element g^-1 *g =e
Ring axiom 3: R3= Two distributive laws connect the additive and multiplicatie structures.
For any x,y,z xX(y+z) = (xXy)+ (xXz)
and (x+y) X z= (xXz) + (yXz)
My attempt. I thought that this would actually be straight forward; that I would just need to put -z as the addition of its inverse. I expected the rest to just fall into place.
Here's what I did:
Left hand side aX (x-z)
= aX(x + z^-1) from G3
= (aXx) + (aXz^-1) from R3
= (aXx)+ (aX -z) from G3
= (aXx)- (aXz), as required
I'm not sure whether I am allowed to just write the last line or whether I have left out some all important step!
Thank you very much in anticipation of your assistance.
You are asking why aX(-z)=(-aXz)? Well, aX(-z)+aXz=aX(-z+z) from your distributive axiom. What does that tell you?
Thank you Dick. I got there! Thank you for your extremely quick reply. I really appreciate your help. Many thanks.
For the record, when the group operation is x+y, the inverse of x is usually written as -x.
Thank you! I shall alter my notation. Much appreciated!
True, it is kind of confusing to be mixing the '*' notation for the group operation with the ring notation of '+' for the group operation, but dndod1 seemed to be dealing with it ok.
