Force and velocity homework problem
The discussion revolves around a physics problem involving a cart of mass 20kg being pushed with a net force of 40N over a distance of 5m. Participants are exploring how to calculate the final kinetic energy and final velocity of the cart, assuming no heat loss.
  • The original poster attempts to understand the role of mass in calculating work and velocity. Some participants suggest using acceleration derived from force and mass to find velocity through kinematic equations. Others discuss the relationship between work done and kinetic energy.
Participants are actively engaging with the problem, offering various approaches to connect work, kinetic energy, and velocity. There is a recognition of the need to clarify the relationship between these concepts, and some guidance has been provided regarding the use of kinematic equations.
There is an assumption of no heat loss in the system, which is a constraint in the problem. The original poster expresses some confusion about the problem's simplicity and their initial oversight.
daem
A cart of mass 20kg, initially at rest, is pushed with a net force of 40N on a flat surface. If the cart is pushed 5m, what is the final KE? What is the final velocity? (Assume no heat loss)
Basically I understand to use: W = F x d to find out the work done, but where does the mass of the cart come into play?
Also, if the cart only goes 5m, how can I find the velocity?
You don't need to use mass for the first part, but for the second. You divide the force by the mass to get its acceleration and then you use one of the thee kinematic equations to find v final using the distance traveled and the acceleration.
Ok, so the accel is 2 m/s^2
Which kinematic equation will solve for velocity now that I know the mass, accel, but not time?
You know work = change in kinetic energy (q1)
If you already have kinetic energy, you can solve q2 :
KE = function of speed and mass
Invert this to find the speed.
Use
Kinetic Energy Gained = Work done
(assuming no heat losses)
1/2 mv^{2} = F.s
therefore v = sqr.rt { 2F.s/m}.
Thanks guys, I completely overlooked that...such an easy problem and I made it harder than it needed.
  • · Replies 32 ·
  • · Replies 24 ·
