Proving that a propagator decays exponentially for spacelike separations
  • Context: Graduate
  • Thread starter Thread starter NanakiXIII
    Propagator
The discussion revolves around the mathematical derivation of the decay behavior of a propagator for spacelike separations, specifically aiming to show that it decays like e^{-m r}. Participants are exploring the integration techniques and the implications of complex analysis in this context.
  • One participant expresses difficulty in understanding the transformation of an integral involving a complex function and the implications of changing integration limits.
  • Another participant introduces the Riemann-Lebesgue lemma, suggesting that the integral of a specific function decays to zero as r approaches infinity, which they believe leads to the desired result.
  • A later reply questions the interpretation of the lemma, indicating a misunderstanding about the decay behavior and seeking clarification on the derivation.
  • Another participant reiterates the application of the Riemann-Lebesgue lemma and mentions the need for regularization when using Jordan's lemma for contour integration.
Participants do not reach a consensus on the application of the Riemann-Lebesgue lemma and its implications for the integral's behavior. There are differing interpretations of the mathematical steps involved and the necessity of contour integration techniques.
There are unresolved questions regarding the treatment of the integral limits and the nature of the branch cut mentioned in the discussion. The participants also highlight the need for regularization in the context of contour integration.
NanakiXIII
I'm trying to show that the propagator for spacelike separation decays like [itex]e^{-m r}[/itex] and I'm stuck. At some point I hit the integral
[tex] \int_{-\infty}^{\infty} \frac{dk}{\sqrt{k^2 + m^2}} e^{i k r}.[/tex]
Integration of complex functions not being my forte, I only managed to get to this point using provided answers, but I don't understand the next step. Apparently the above integral is equal to
[tex] 2 \int_0^{\infty} dy e^{-(y+m) r} \frac{1}{\sqrt{(y+m)^2 - m^2}},[/tex]
where the substitution [itex]k = i(m+y)[/itex] has been made. Now there are several things I don't understand. Firstly, I see how the integrand has changed, but since the integrand is not an even function of [itex]k[/itex] or [itex]y[/itex], how is it possible to change the integration limits to [itex]0[/itex] and [itex]\infty[/itex]? Secondly, shouldn't the integration now be along the complex axis, i.e. shouldn't the upper limit be [itex]i \infty[/itex], due to the [itex]i[/itex] in the substitution? Finally, there is also a bit of text where the author says the integrand has a branch cut going from [itex]i m[/itex] to [itex]i \infty[/itex], and one has to fold the contour of the integral around this cut. I don't see what that cut has to do with anything whatsoever, or exactly what contour he is using.
Could someone help me along with this? I think I understand the rest of the derivation, this is the last link I need.
Consider Fa(k) = 1/sqrt(k^2 +m^2) for |k|<=a & 0 otherwise.
Applying the Riemann-Lebesgue lemma , the integral of exp(irk)Fa(k) =o(r) as r-> inf.
If you argue carefully & let a->inf. , you'll get the desired result.
I don't quite follow. I'm not familiar with this lemma, but it seems to say that the integral goes to 0 as [itex]r[/itex] goes to infinity, not to [itex]O(r)[/itex] (I'm assuming that's what you meant). Could you elaborate a little? This is not homework, I'm just trying to understand the author's derivation.
I figured it out. Thanks, though.
Could you elaborate on this a little bit more?
Since the integral of NanakiXIII's question is the same as
https://www.physicsforums.com/showthread.php?t=420759
But, there is a problem to use Jordan's lemma.
To perform the integral along the keyhole contour, we need some regularization as weejee did in that series of post.
