Hot water and Sunburns?
by oexnorth
Tags: alleviation, cures, hot water, skin pores, sunburn
oexnorth
oexnorth is offline
#1
Aug8-10, 08:36 PM
P: 11
I have heard that warm water helps to open the pores of your skin, and therefore, can release more heat which will aid in the treatment of a sunburn. I was immediately skeptical, but after a few searches I found answers both for and against it. What are the actual physics behind this, and, if a definitive answer can be given, what is it? Thank you.
Phys.Org News Partner Medical research news on Phys.org
Filipino tests negative for Middle East virus
Philippines boosts MERS monitoring after UAE nurse scare
Treating depression in Parkinson's patients
zhermes
zhermes is offline
#2
Aug8-10, 09:07 PM
P: 1,262
Personally, I'm pretty sure its completely ridiculous! :P
A sun 'burn' isn't from your skin getting too hot, its from radiation (mostly ultraviolet) damage. People often get sunburns while skiing, due to the reflectivity of the snow; or on cloudy days (cool, but still irradiated).
Hot water, and opening poors will have ZERO effect.
oexnorth
oexnorth is offline
#3
Aug8-10, 11:35 PM
P: 11
Quote Quote by zhermes View Post
I appreciate your reply and I thank you. Can you direct towards something that I can see for myself why warm/hot water doesn't work?
Mech_Engineer
Mech_Engineer is offline
#4
Aug8-10, 11:44 PM
Sci Advisor
PF Gold
Mech_Engineer's Avatar
P: 2,234
Quote Quote by oexnorth View Post
It isn't our job to prove to you it doesn't work. The claim is ridiculous and does not address the root cause of a sunburn- UV damage. Unless you can post a credible site which proves it does help, this thread was done before it started.
zhermes
zhermes is offline
#5
Aug8-10, 11:58 PM
P: 1,262
http://en.wikipedia.org/wiki/Sun_burn is plenty.
hypatia
hypatia is offline
#6
Aug9-10, 03:17 PM
hypatia's Avatar
P: 1,296
A sunburn is still considered a burn {generally classified as a superficial or first-degree burn}, and should be treated as such.
If the area has fluid filled blister, seek medical aid. Never apply heat to a burn. Use cool water, and lotions developed for treating burns. Never use salves or ointments that would trap the heat in.
http://www.mayoclinic.com/health/sun...atment/AN01423
oexnorth
oexnorth is offline
#7
Aug9-10, 06:57 PM
P: 11
Thanks, hypatia. When I first heard that running warm or hot water over your skin to open the pores to let more heat out, I had serious doubts. Hot water might open the pores but it still adds a lot of heat to the system, so any benifits are immediately countered. Most of what I've read and the help that I've gotten from the people on this forum have put that myth to rest. Thanks again.
eyeofdivine
eyeofdivine is offline
#8
Aug12-10, 04:08 PM
P: 6
NHS choices can give quite a good comprehensive way to treat mild ailments.
http://www.nhs.uk/Conditions/Sunburn...Treatment.aspx
oexnorth
oexnorth is offline
#9
Aug12-10, 11:40 PM
P: 11
Does the Physics Forums edit posts? A couple of comments were deleted from this one, including my own. I don't like negative back-and-forths, but I also respect freedom of speech. Can someone tell me what happened to those posts? I have backups if anybody wants to see what I mean.
Monique
Monique is offline
#10
Aug13-10, 02:07 AM
Emeritus
Sci Advisor
PF Gold
Monique's Avatar
P: 4,615
Check your inbox with private messages.
Register to reply
Related Discussions
Thermodynamics: Water vapor vessel plunged into water ice bath Engineering, Comp Sci, & Technology Homework 5
energy loss converting water to hydrogen then back to water General Physics 2
How long does tans and sunburns last? General Discussion 4
HELP! relationship between rate of flow of water and height of water column Introductory Physics Homework 1
Basic question regarding triple point of water and physical properties of water Introductory Physics Homework 9
