Thread Closed
chebyshevs theorem : find k so that at most 10%
Share Thread Thread Tools
Aug9-10, 07:08 AM   #1
the test scores for a large statistics class have an unknown distribution with a mean of 70 and a standard deviation of 10
find k so that at most 10% of the scores are more than k standard deviations above the mean.
I'm a bit confused by the question it self.
does the question means :
1-1/k^2 = 0.1
k = 1.05
or
1-1/k^2 = 0.2
k = 1.12
or
1-1/k^2 = 0.8
k = square root 5 = 2.23
pls help, thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Aug9-10, 09:27 AM   #2
to avoid being flamed for homework type of question, I added my own opinion towards this question. your help is very much appreciated.
Aug9-10, 10:59 PM   #3
Quote by idioteque View Post
I misread your question. The minimal value for k given "at most" 10% k SDs above the mean would be [tex]1-1/k^2=0.8[/tex] so [tex]k=2.236[/tex]. This assumes your distribution is perfectly symmetrical.
Aug10-10, 05:37 AM   #4
'at most' 10%.
why take the other remaining 80%?
it asked for 'at most' 10%.
doesn't this mean anything not greater than 10%?
if it asked 'at least' 10% then anything greater than 10%
Aug10-10, 06:11 AM   #5
'at most' 10%.
why take the other remaining 80%?m
80% of the test scores are within 2.236 SD of the mean. 10% are at least 2.236 SD above the mean, 10% at least 2.236 SD below the mean. This is the minimal value of k. If you want to be sure that at most 10% are more than k SD above the mean, take any arbitrary value of k greater than 2.236. That's the way I read it anyway.
Aug11-10, 07:15 AM   #6
ok thank you. I got it.
the keyword is above the mean.
the value of k before the last 10% of each side(20%). so 80% is in between the 20%
is how I interpreted it as it is.
correct?
Aug11-10, 12:21 PM   #7
correct?
Correct.
Thread Closed
Thread Tools
Similar Threads for: chebyshevs theorem : find k so that at most 10%
Thread Forum Replies
Using the Squeeze Theorem to find Limit Calculus & Beyond Homework 2
Chebyshevs Theorom, can u figure this out? Set Theory, Logic, Probability, Statistics 0
Mean Value Theorem - Find the values of c Calculus & Beyond Homework 3
Help with using the Squeeze Theorem to find a limit. Calculus & Beyond Homework 12
Pythagorean Theorem to find the resultant Introductory Physics Homework 1
