Extraction of iron on a match head
The discussion revolves around the extraction of iron from iron oxide using a match head, focusing on the sources of carbon in the reaction and the role of sodium carbonate in the process. Participants explore the chemical equation involved and the materials used in the match head.
  • One participant questions the source of carbon in the reaction, suggesting it may come from the wood in the match.
  • Another participant notes that carbon is present in the red part of the match as carbon black and binders like gelatin or starch, which can also provide carbon.
  • There is a suggestion that paraffin, used in match sticks, could also be a source of carbon.
  • Participants express uncertainty about the necessity of sodium carbonate, with one proposing that it helps mix iron oxide with carbon by melting and increasing contact area.
  • Another participant describes sodium carbonate as a stabilizing agent that keeps the reaction components in place until the flame reaches them.
Participants do not reach a consensus on the exact role of sodium carbonate or the sources of carbon, indicating multiple competing views and ongoing uncertainty.
Some assumptions about the materials and their interactions are not fully explored, and the discussion does not resolve the specifics of the chemical processes involved.
Moogie
Hi
Please look at this link. It is only very brief. It describes how to extract iron from iron oxide on a match head.
My questions are:
where does the carbon come from in this equation
Iron(III) oxide + carbon → iron + carbon dioxide
2Fe2O3(s) + 3C(s) → 4Fe(s) + 3CO2(g)
Is it from the wood in the match?
Why sodium carbonate is needed? The page says:
The sodium carbonate fuses easily and brings the iron oxide into close contact with the carbon.
I don't really know what that means
thanks
Chemistry news on Phys.org
No link to look at.
Moogie said:
My questions are:
It seems so, it says to make the match burn to about half lenght.
IMO it means that sodium carbonate melts and so mixes iron oxide within the liquid phase, this shoud make the solid particles of oxide penetrate inside the carbon increasing the area of contact.
The carbon is added as an ingredient in the red part of the match. It can be present as carbon black and as a binder. The binders can be (but aren't necessarily limited to) gelatin or starch, both of which can be sources of carbon. Most match sticks (not the heads) are impregnated with paraffin which can volatilize and be a source of carbon as well. Of course there is the wood or paper substrate as well.
Sorry, I still don't understand why sodium carbonate is needed, thanks
I believe the match stick's head is just moistened a bit and rolled in some iron oxide followed by the sodium carbonate. If you have ever watched a match burst into flame you might expect a powder on its surface to be launched off into space! The sodium carbonate melts and keeps it put until the flame front reaches it and some chemistry has a chance to happen. Think of the sodium carbonate as this reaction's post it note... STAY THERE UNTIL I CAN DEAL WITH YOU.
Thank you.
17K
  • · Replies 19 ·
11K
16K
  • · Replies 26 ·
