Help with an acceleration graph problem.
The discussion revolves around a problem involving an acceleration graph and its relation to determining the total distance traveled by a particle over a specified time interval. Participants are exploring concepts related to kinematics and motion analysis.
  • Participants discuss breaking down the motion into periods of constant acceleration and calculating areas under the velocity graph to find distance. Questions about initial conditions, such as initial velocity, are raised, and there is mention of confusion regarding the correctness of calculated results.
The discussion is ongoing, with participants providing guidance on checking calculations and suggesting the use of kinematic equations for verification. There is an exploration of different interpretations of the problem, particularly regarding the initial velocity and the method of calculating distance.
There is uncertainty regarding the initial velocity, which may affect the calculations. The original poster has encountered issues with an online assignment checker, indicating potential discrepancies in their results.
FabioTTT
I can't for the life of me figure this out. The question is, based on this graph, determine the total distance the particle traveled during the first 20 seconds.
http://seminario.no-ip.com/graph.gif
I graphed the velocity graph just fine based on the acceleration graph. but the position graph is a little trickier. Can anyone help me out?
I assume you are given the initial velocity? The motion is three periods of constant acceleration: 0 to 10 seconds, 10 to 15 seconds, and 15 to 20 seconds. Do it step by step, one period at a time.
thanks Doc Al. I did this, dividing the three regions of the velocity graph and calculated the area beneath each of those regions. I came up with 215 meters but the online assignment checker counted it as wrong so I am a little confused.
what's the initial velocity?
Two things to do. (1) If you are familiar with the kinematic equations (such as [itex]x = x_0 + v_0 t + 1/2 a t^2[/itex]) you can just calculate the distance as a double check of your work. (2) You can show us your velocity graph and we can take a look at how you solved this.
