Dis-ambiguate: derivative of a vector field Y on a curve is the covariant of Y
The discussion focuses on proving the relationship between the covariant derivative of a vector field W with respect to a curve's tangent vector a'(t) and its derivative along the curve, specifically showing that Cov W w.r.t. a'(t) equals (W(a))'(t). The second part deduces that the derivative of a vector field Y on a curve a(t) is almost equal to Cov Y w.r.t. a'(t), highlighting the distinction between vector fields defined on curves versus those defined in R^3. The definitions provided from O'Neill's Elementary Differential Geometry are crucial for understanding these relationships.
  • Understanding of covariant derivatives in differential geometry
  • Familiarity with vector fields and their properties
  • Knowledge of regular curves and tangent vectors in R^3
  • Proficiency in calculus, particularly differentiation of vector functions
  • Study the properties of covariant derivatives in O'Neill's Elementary Differential Geometry
  • Learn about the implications of vector fields on curves in differential geometry
  • Explore the concept of tangent vectors and their applications in R^3
  • Investigate the differences between vector fields defined on curves versus those in higher-dimensional spaces
Students and professionals in mathematics, particularly those studying differential geometry, as well as researchers dealing with vector fields and their derivatives in theoretical physics or engineering.
Dignifiedhelp
This two-part problem is from O'Neill's Elementary Differential Geometry, section 2.5.
Let W be a vector field defined on a region containing a regular curve a(t). Then W(a(t)) is a vector field on a(t) called the restriction of W to a(t).
1. Prove that Cov W w.r.t. a'(t) equals (W(a))'(t) where "Cov W w.r.t a'(t)" reads "the covariant of W with respect to a'(t)."
2. Deduce that the straight line in Definition 5.1 (below) may be replaced by any curve with initial velocity v. Thus the derivative Y' of a vector field Y on a curve a(t) is (almost) Cov Y w.r.t. a'(t).
Definition 5.1. Let W be a vector field on R^3, and let v be a tangent vector to R^3 at the point p. The the covariant derivative of W with respect to v is the tangent vector (W(p+tv))'(0) at the point p.
The following definition is useful for part (2) since it distinguishes between a vector field and a vector field on a curve.
Definition 2.2. A vector field on a curve 'a' from I to R^3 is a function that assigns to each number t in I a tangent vector Y(t) to R^3 at the point a(t).
Part (1) was fairly straight-forward, using the definitions of covariant derivative and what it means to differentiate a composition.
Part (2) has two parts. My approach to the first part is the following, and I believe it to be correct. The idea is to define a function on curves a(t) and show that it agrees with the covariant derivative with respect to a vector v at a point p for all curves a(t) such that a(0)=p and a'(0)=v. Part (1) can be used to show the function is well-defined and that it indeed equals the covariant. The second part, starting at "Thus" is where I'm having trouble. It's with the use of the word "almost." To me, if Y is a vector field on a curve a(t), then using the definition of covariant, straight-line or otherwise, makes no sense because Y(a(t)) is not defined (i.e., Y is not defined on R^3, only R). So I thought this might be the almost part. However, what's 'almost' about it? I was thinking that perhaps given Y on a(t) that a vector field Ybar could be defined such that Ybar equals Y(a(t)), and that then Y' would equal the covariant of Ybar instead of Y. However, I don't think I can 'always' define such a Ybar.
Thank you in advance for your guided help. This is my first posting.
In the "Relevant equations" section I meant to say "Ybar composed with 'a' equals Y," not the other way around.
Attached is the PDF of an easier-to-read TeX version.
