| Thread Closed |
inverse random integer k |
Share Thread | Thread Tools |
| Aug10-10, 10:17 PM | #1 |
Please help - I am helping a student who is trying to translate Ong-Schnorr to C++ or VB.net language. My major was electronics so I am not sure how to interpret inverse random integer k. Any one ? or suggest me a reference to read on - much thanks, newbie
Ong-Schnorr-Shamir (from Briuce's Applied Cryptography p.418 chp 20.5) This signature scheme uses polynomials modulo n [1219,1220]. Choose a large integer n (you need not know the factorization of n). Then choose a random integer, k, such that k and n are relatively prime. Calculate h such that h = –k^-2 mod n = -(k^-1)^2 mod n The public key is h and n; k is the private key. To sign a message, M, first generate a random number, r, such that r and n are relatively prime. Then calculate: S1 = 1/2 * (M/r + r) mod n S2 = k/2 * (M/r – r) mod n The pair, S1 and S2, is the signature. To verify a signature, confirm that S1^2 + h * S2^2 identical to M (mod n) |
| Aug11-10, 01:21 AM | #2 |
4 mod 10 = 4 10 mod 3 = 1 10 mod 4 = 2 in Schnorr h= -k^(-2) mod n h= -(k^(-1))^2 mod n Hence for 2 primes 9 mod 2 = 1 (3)^2 mod 2 = 1 Therefore k^(-1) = 3 Is this right please your opinion please - thanks in advance |
| Aug11-10, 11:54 AM | #3 |
I'm not entirely clear what your question is, but if it's how to get a (sorta) random number in C... The stdlib has: int rand ( void ); which you can seed with srand(). A man page is here:
http://www.cplusplus.com/reference/c.../cstdlib/rand/ |
| Aug11-10, 06:29 PM | #4 |
Recognitions:
I don't know about encryption, but know a bit about finite field math and don't understand your examples. Using 5 as n, you get these tables for finite field math modulo 5:
Code:
add subtract (left - top) 0 1 2 3 4 0 1 2 3 4 -------------- -------------- 0| 0 1 2 3 4 0| 0 4 3 2 1 1| 1 2 3 4 0 1| 1 0 4 3 2 2| 2 3 4 0 1 2| 2 1 0 4 3 3| 3 4 0 1 2 3| 3 2 2 0 4 4| 4 0 1 2 3 4| 4 3 2 1 0 multiply divide (left / top) 0 1 2 3 4 0 1 2 3 4 -------------- -------------- 0| 0 0 0 0 0 0| x 0 0 0 0 1| 0 1 2 3 4 1| x 1 3 2 4 2| 0 2 4 1 3 2| x 2 1 4 3 3| 0 3 1 4 2 3| x 3 4 1 2 4| 0 4 3 2 1 4| x 4 2 3 1 20 = 1 21 = 2 22 = 4 23 = 3 In the general case of a finite field number to determine (-1/k)2 , you first find i = ( (0 - k) mod n). Then you need to do a table lookup, or implement an algorithm to solve for j where ((i x j) mod n) = 1, then 1/i = j. (1/i)2 would be ((j2) mod n). |
| Thread Closed |
| Thread Tools | |
Similar Threads for: inverse random integer k
| Angular momentum - integer or half-integer | Quantum Physics | 2 | ||
| Proof Question: Prove integer + 1/2 is not an integer | Calculus & Beyond Homework | 4 | ||
| Prove that the inverse of an integer matrix is also an integer matrix | Precalculus Mathematics Homework | 7 | ||
| Every integer can be written as a sum of a square and square free integer | Calculus & Beyond Homework | 5 | ||
| Binomial Random Variable With Non-Integer value | Calculus & Beyond Homework | 5 | ||
