Thread Closed
Change of variable - joint p.d.f
Share Thread Thread Tools
Aug11-10, 08:28 AM   #1
X and Y uniformly distributed on the disc:
1/pi, x^2+y^2 <=1
X=Rcos(theta), Y =Rsin(theta)
0<=R<=1, 0<=theta<=2pi
Find the joint PDF of R,theta
3. The attempt at a solution
g(R,theta)=f(x,y)*abs(jacobian)
The Jacobian is R
The joint PDF is then simply R/pi = 1/pi (since area is R^2 pi = 1 and R = 1)
Is it that simple?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Aug11-10, 03:03 PM   #2
Recognitions:
Homework Helper Homework Help
as X & Y are unifromly distrubted, the probability of ocurring in any area A is proportinal to A
in cartesian coordinates an area element is dx.dy so the joint pdf is
[tex] p_{X,Y}(x,y).dx.dy \propto dx.dy [/tex]
in polar coordinates an area element is [itex]r.dr.d\theta [/itex] so the joint pdf is
[tex] p_{R, \Theta}(r,\theta).dr.d\theta \propto r.dr.d\theta [/tex]
Aug11-10, 05:37 PM   #3
Thanks. So in the polar space, the area is R.pi where R is 1. Since this should equal 1 then each point and hence the joint PDF is 1/pi
This makes sense because we are still looking at the same area just in polar coordinates.
I'd just like to validate that the joint PDF is 1/pi. Is that the way to define it?
Aug11-10, 08:44 PM   #4
Recognitions:
not quite - see above I was a little mroe explicit in writng out the form of the pdfs
in cartesian coords, infinitesiaml area elelment is [itex] dA = dx.dy [/itex] , and the normalised joint pdf is [tex] p_{X,Y}(x,y)dxdy = \frac{1}{\pi}dx.dy [/tex]
in polar coordinates you need to account for the jacobian you found. The infinitesimal area elelment is [itex]dA = r.dr.d\theta [/itex]
Aug11-10, 09:28 PM   #5
Thanks a lot. Understand now. Appreciate your help
Aug11-10, 11:28 PM   #6
Recognitions:
no - the area of a circle is [itex] \pi r^2 [/itex]
an ifinitesiaml area element in polar coords [itex]dA = r.dr.d\theta [/itex]
try integrating your joint pdf over [itex]r \in [0,1), \ \ \theta \in [0, 2 \pi)[/itex] and see if it sums to 1
Thread Closed
Tags
jacobian, joint pdf
Thread Tools
Similar Threads for: Change of variable - joint p.d.f
Thread Forum Replies
Variable Change General Math 69
PDE - Change of variable Differential Equations 4
Change of Variable Calculus & Beyond Homework 0
change fo variable 2 Introductory Physics Homework 0
Change of variable... Calculus 1
