Solution of silver ions turning amber
The discussion revolves around the phenomenon of silver ion solutions turning amber in color after a period of time. Participants explore potential chemical reactions and processes that could explain this color change, including the formation of silver oxides, nanoparticles, and other compounds. The scope includes theoretical reasoning and experimental observations related to chemistry.
  • One participant notes that the initial clear solution turns amber, hypothesizing that Ag+ ions may have been reduced to neutral Ag atoms, which could absorb light.
  • Another suggests that the amber color might be related to the formation of silver oxides and recommends adding a base to test for color changes.
  • A different viewpoint proposes that photochemical reduction of AgCl could lead to the formation of silver nanoparticles, which might contribute to the color change.
  • One participant mentions that solutions without AgCl can also turn amber, speculating that oxidation to Ag2O is a plausible explanation, while questioning the spontaneous reduction of cations.
  • Another participant argues against Ag2O being the cause, stating that adding a strong base produces silver hydroxide, which reacts with oxygen to form the oxide, potentially deepening the color.
  • There is a suggestion to write a reaction equation for the formation of silver oxide from silver hydroxide and oxygen.
  • One participant proposes a specific reaction equation for the conversion of silver hydroxide to silver oxide but admits to not having seen it balanced before.
  • Another participant introduces the idea that CO2 absorption could lead to the formation of silver carbonate, and mentions the hydrolysis of water at high voltages, which introduces oxygen and hydrogen gas that may react with silver.
  • A later reply reiterates the reaction involving silver hydroxide and oxygen, seeking confirmation on its balance.
  • One participant concludes that Ag+ ions were already oxidized and do not change their oxidation state, implying no need for an oxidizer.
Participants express multiple competing views regarding the cause of the amber color, with no consensus reached on a single explanation. Various hypotheses about the chemical processes involved are presented and debated.
Some assumptions about the chemical reactions and the conditions under which they occur remain unverified. The discussion includes references to specific reactions and compounds without definitive conclusions on their roles in the observed color change.
cnidocyte
I've been making solutions of silver ions by hooking 20-30V up to 2 silver electrodes in distilled water and noticed something interesting. The solution starts off as clear and by adding a bit of NaCl, AgCl precipitates out so there's definitely Ag+ ions in there. If I leave the solution for a few days it turns amber coloured. This is the colour
whats going on here? I haven't bothered to retest for Ag+ ions but the only theory I've come up with is that the Ag+ ions have been reduced somehow and neutral Ag atoms absorb some light.
Chemistry news on Phys.org
Hmm, I'm not sure, but it's likely that it is related to the formation of silver oxides. Add some base and see if the color deepens.
Photochemical reduction of the AgCl back to nanoparticles of silver, maybe?
Acut: I added NaOH but no color change at all.
minerva: Solutions with no AgCl turn amber.
Oxidation to Ag2O is the best theory so far IMO. I did read that silver nano particles absorb some wavelengths of light and the result is an amber color though so I wonder if the cations could be getting reduced somehow. Does that kinda thing occur? Spontaneous reduction of cations. Enough theorizing though I'll just add some NaCl and look for AgCl precipitate.
Hm, I think it's not Ag2O.
Addition of strong base to Ag+ solutions produces silver hydroxide, which, in turn, reacts with oxygen from the air to form the oxide. So addition of silver hydroxide would either deepen the collor or produce more of this amber-collored compound.
I'm not a silver expert, however.
Try to write reaction equation.
I'd guess this,
2Ag(OH) + O2 -> Ag2O + 2OH-
But I've only read its description, never saw its chemical equation.
So you are electrolyzing in distilled water, eh? Not very efficient, at least at first. It is likely that CO2 is being absorbed into the solution and you are making small amounts of silver carbonate.
At 20 to 30 V you are certainly hydrolyzing water as well so your solution and your silver electrodes have oxygen present as well as the reducing hydrogen gas. Hydrogen gas can react with silver to produce silver hydride which can be a variety of colors from red to black.
Acut said:
I'd guess this,
Check if it can be balanced.
@Borek: Hm, I never realized that!
But I'm sure I read about this reaction.
It's amazing how much I learn with your posts!
In short - Ag+ was already oxidized, it doesn't change its oxidation state, so it doesn't need oxidizer.
9K
9K
16K
24K
12K
