A question about reference system and time dilation
The discussion revolves around the concepts of time dilation and reference frames in the context of special relativity, particularly focusing on the twin paradox. Participants explore the implications of relative motion and acceleration on the aging process of two observers, one stationary and one traveling at a significant fraction of the speed of light.
  • One participant describes observing time dilation from both perspectives, noting that each observer sees the other's clock ticking slower, leading to confusion about who ages faster.
  • Another participant explains that the time shown on each observer's clock depends on their four-dimensional path through spacetime, suggesting that the perception of time dilation does not affect the actual aging process when they reunite.
  • Some participants clarify that acceleration breaks the symmetry of the situation, indicating that the twin who accelerates will age less than the one who remains in an inertial frame.
  • There is a discussion about the nature of acceleration, with one participant asserting that proper acceleration is absolute and can be felt, unlike relative motion which is perceived differently by each observer.
  • One participant emphasizes that the twin paradox can be analyzed using special relativity, provided certain assumptions about the acceleration are made.
  • Another participant suggests that the topic is frequently discussed and may benefit from a dedicated FAQ to address common questions.
Participants generally agree on the effects of acceleration in the twin paradox and the nature of time dilation, but there remains uncertainty about the implications of perspective and how to reconcile the differing observations of aging.
Participants express limitations in understanding the nuances of acceleration and its effects on aging, indicating a need for further clarification on the relationship between proper acceleration and relative motion.
atomqwerty
Hi everyone,
These days I've been reading about relativity (special) in a book of general physics, and I have a doubt about the reference system:
If I stay on Earth and I observe a rocket traveling away from the Earth with a great velocity (let's be 0.5c), and I notice that time inside the rocket is slower than on earth, ok, that's allright, but, in the same way, the person who travels in the rocket will see that he's got velocity zero and the Earth moves at 0.5c, thus a clock ticks slower on the earth.
Which one of those people will get older faster? For each one will be himself, and no the other, whose seconds are loooong.
Twin paradox confuses me...
Thanks to all.
In a nutshell, if two travellers meet up and synchronise watches then go on separate journeys, when they meet up again to compare watches, the time shown for each will depend on the 4 dimensional path they took through space-time. Observing that each others clocks appear slow doesn't come into it - it's a different phenomenon.
like, Mentz114, pointed out, you are confusing two different phenomenum
Phenomenum first:
I and you are moving away from each other. You 'see' my clock ticking slowly and I 'see' your clock ticking slowly. I see you are still young while I am old, and you see the same! (if we are able to maintain our 'seeing' for that long. :) ).
This is time dilation.
Both are right. This is in some respect same as:
You and I are in opposite side of a bridge. I see you too small, you see me too small: Who is infact small? who is correct?
[Ask if its not clear to you.]
Phenomenum second:
Ok, let's continue from the previous. I see you young, while I am old and ditto for you.
NOW, if you make an effort (like fire your rocket engine) and make the turn over and return to me, then on our meeting you will be "infact younger". If instead I make the effort I will be yonger.
This is the twin paradox.
[Ask if its not clear]
Thank you for the answer.
So, If I'm not wrong, if you and I are moving (each one from the other ones reference system) and one of us changes his acceleration,(becomes a non inertial r.s.), for example, you, then when you came back to my rocket and we met up again, I'd be older than you, due to your velocity change. But, isn't his once again a problem of perspective? I mean, if you decelerate, you could say that it was me that slowed down my velocity.
I'm afraid that the problem about acceleration/deceleration must be defined in relation to the space-time continuum, or smthg like that, and not to the other's perspective, cause if so, we both had the same age after your backing home travel. Is this correct?
Thanks again,
Carlos
Yes, you are correct. Acceleration is not relative. Someone in a spaceship can easily tell if they are accelerating or not, so it's not like uniform motion in that respect. In the case where one traveller accelerates and the other does not, there is no reciprocity, only the accelerating one feels the force.
Carlos
Yes it is. This is called the 'absolute' or 'proper' acceleration. The other type called the 'coordinate' acceleration is the relative acceleration. Relative acceleration only depends on our 'seeing' and not 'feeling'. For a relative acceleration to exist one or both of the entity must be in proper acceleration.
It is in fact this proper acceleration that makes the distinction in the twin paradox. If you want to dig upon how much difference in time this 'proper' acceleration creates, then that's the subject of 'general relativity' at which I know nothing. Nevertheless, you can find-out the time difference in the twin paradox by using special relativity alone; provided that you make one assumption--> The turning over twin (the accelerating twin) turns over almost instantly, so that he remains in non-inertial frame for very short time, short enough to be ignored!
Happy learning.
We really, really need a sticky FAQ on this topic. Nothing against the people asking it. It's a reasonable question to ask. But it gets asked and answered multiple times per week.
Great example, by the way! I hope you don't mind if I use that :wink:
Thanks and yeah, use it freely. :)
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 44 ·
  • · Replies 70 ·
  • · Replies 40 ·
  • · Replies 54 ·
