| Thread Closed |
Codes for constructing matrix of Hamiltonion of 2D square Tight-bonding model |
Share Thread | Thread Tools |
| Aug13-10, 07:01 AM | #1 |
Hello,
Does anyone know how to write codes for constructing the matrix of Hamiltonion of 2D square Tight-bonding model. Then diagonalize it. Any language is OK. (Fortran is best) |
| Aug23-10, 07:05 AM | #2 |
Hello,
This program shows the principle of diagonalizing a matrix in fortran, using a 2D geometry. To compile, write gfortran -llapack 2D.f90 then write ./a.out to run the program Or ifort -llapack 2D.f90 Code:
module shared !every function and routine which
implicit none !includes the module shared can use its
real*8, allocatable :: Hdiag(:,:),eigenvalues(:) !variables
end module shared
program diag
use shared !now the program diag knows about Hdiag and eigenvalues
implicit none !this makes sure one has do define everything explicitly
integer :: nsize !size of the matrix to be diagonalized
integer :: i,j,icount,jcount,norb
integer :: i1,i2,j1,j2
real*8 :: v
norb = 5 !size of system
nsize = norb*norb !size of hamiltonian
allocate(Hdiag(nsize,nsize)) !This is the matrix to be diagonalized
allocate(eigenvalues(nsize)) !after diagonalization, this vector
!contains the eigenvalues
v = -1.0 !this is the hopping parameter
!Now we construct the hamiltonian, and we do that by first looping over
!j, and then i. This are non-periodic boundary conditions.
icount = 0
jcount = 0
do i1=1,norb
do j1=1,norb
jcount = 0
icount = icount + 1
do i2=1,norb
do j2=1,norb
jcount = jcount + 1
if (abs(i1-i2) + abs(j1-j2) == 1)Hdiag(icount,jcount) = v !if distance == 1, put hopping parameter = v
write(11,*)'hop(',icount,jcount,')=',Hdiag(icount,jcount) !this prints the hamiltonian to disc
end do
end do
end do
end do
call diagonalize(nsize) !now Hdiag will be diagonalized.
!After diagonalization, Hdiag(:,:) will contain the eigenvectors,
!Where Hdiag(:,1) is the first eigenvector, Hdiag(:,2) the second and so on
!and eigenvalues(1) will contain the eigenvalue corresponding to
!eigenvector 1, and so on.
do i=1,nsize
write(*,*)'eigenvalue:',i,eigenvalues(i) !writing eigenvalues to screen
end do
end program diag !program is finished
subroutine diagonalize(ndiag) !Diagonalizes the matrix Hdiag
use shared
implicit none
real*8, allocatable :: work(:)
integer, allocatable :: iwork(:)
character job, uplo
external dsyevd
integer nmax, lda, lwork, liwork, info,ndiag
nmax=ndiag
lda=nmax
lwork=4*nmax*nmax+100
liwork=10*nmax
allocate(work(lwork),iwork(liwork))
job='v'
uplo='l'
call dsyevd(job,uplo,ndiag,Hdiag,lda,eigenvalues,work,lwork,iwork,liwork,info)
if (info > 0) then
write (*,*) 'failure to converge.'
stop
endif
deallocate(work,iwork)
return
end
| Thread Closed |
| Thread Tools | |
Similar Threads for: Codes for constructing matrix of Hamiltonion of 2D square Tight-bonding model
| Tight-binding model | Atomic, Solid State, Comp. Physics | 4 | ||
| Tight binding model, help please! | Advanced Physics Homework | 0 | ||
| Tight binding model and bandwidth | Advanced Physics Homework | 2 | ||
| DFT, tight binding, Van Vechten's model.... | Atomic, Solid State, Comp. Physics | 0 | ||
