Solve the Mystery: Find the Jam Tin's Depth Under Water
The discussion revolves around a physics homework problem involving the pressure exerted on a jam tin submerged in water. Participants explore the relationship between atmospheric pressure, water depth, and the volume of air inside the can, applying concepts such as Boyle's Law and hydrostatic pressure. The scope includes theoretical reasoning and mathematical calculations related to pressure in fluids.
  • Homework-related
  • One participant calculates the pressure at a depth of 1 meter in water to be 10 kPa, leading to confusion about why the total depth resulting in 200 kPa pressure is stated as 10 meters.
  • Another participant suggests that when the can is half filled, the pressure must be twice that at the surface, implying a total pressure of 200 kPa.
  • A different viewpoint questions the interpretation of the can being submerged, referencing an experiment with a bottle that may relate to the problem.
  • Some participants discuss the implications of halving the volume of air in the can and how that relates to pressure changes, with one asserting that the pressure inside the can is influenced by both atmospheric pressure and the pressure from the water above it.
  • One participant expresses uncertainty about how to algebraically demonstrate that the pressure is 100 kPa.
  • Another participant reiterates Boyle's Law, suggesting that if the volume is halved, the pressure must double, leading to a calculation that supports the idea of needing 10 meters of water to achieve the necessary pressure.
Participants express differing interpretations of the problem, particularly regarding the relationship between pressure, volume, and depth. There is no consensus on the correct approach to solving the problem, and multiple competing views remain regarding the calculations and underlying principles.
Participants note various assumptions, such as the initial conditions of pressure and volume in the can, and the effects of atmospheric pressure on the calculations. Some express confusion about the implications of halving the volume and how it affects pressure, indicating that further clarification may be needed.
This discussion may be useful for students studying fluid mechanics, particularly those grappling with concepts of pressure in submerged objects and the application of Boyle's Law in practical scenarios.
ghostanime2001
Atmospheric pressure is 100 kPa and a depth of 1m in water is equivalent in pressure to 10 kPa. A jam tin, open end down, is forced under water until the water half fills the can. At this stage, how far beneath the surface is the can? (ans is 10 m)
I DONT'T UNDERSTAND WHY 10 metres! T_T
So from what I know, I must use Boyle's Law.
P1 = 100 kpa
P2 = ?
V1= ?
V2 = 1/2 V1
P1V1=P2V2
100V1=P2(1/2 V1)
100V1=1/2 P2V1 <---Don't the V1's cancel out?
200=P2
using ratio's:
[tex]\frac{1 m}{10 kPa}[/tex] = [tex]\frac{x}{200 kPa}[/tex]
x=20 m
Why is my answer different from my worksheet (10m) ??
Any help is greatly appreciated!
Thanks
when the water half fills the can there must be twice as much pressure as at the surface
so the question is asking what depth of water s equal to atmopsheric pressure.
Atmopsheric pressure is given as 100KPa - what does this mean?
(what column of water would have the same weight)
but isn't the water "Underwater" ? so I am getting the picture has not floating on top but under.. and.. isn't there an experiment where u have a bottle or something and u flip it and force it down the inside of the bottle has air in it and not water. Isn't this a similar application of that experiment?
I understand that outside the water the pressure of the atmosphere is 100 kPa and doesn't "half fills the can" mean the volume is reduced by half of the original volume of the can? so 1/2 V1 = V2 does make sense right?
How would I show algebraically that the pressure is 100 kPa?
200 kPa which i calculated. 100 kPa at the surface
Thats a weird question.. the pressure underneath the water PLUS the pressure from the atmosphere totals 200 kPa!
I think this is where I went wrong. I assumed that 200 kPa was the pressure the gas inside the can was experiencing and I had wrongly assumed that the 200 kPa was from the water only!
From what i can understand from this question. At first when the can is opened there is already pressure on it right? from the atmosphere and then let's say i forced the can down to 1 m underneath water that means the total pressure is 100 kPa + 10 kPa (from 1m in water) = 110 kPa total pressure. since 100 kpa is already forced upon the water and the can is INSIDE the water all i had left was 100 kpa more pressure from water therefore totalling 200 kpa. Am I right in this line of thinking? I am typing this up really fast. I hope I am not wrong :( If I am incorrect in my line of thinking.. please help me correct it.. Thanks guys! that was puzzling :S but good!
ORRR i can use boyle's law where it says that PV = constant!
lets say:
P1=100
P2=200
V1=?
V2=1/2 V1
plug and play into boyle's expression:
P1V1=P2V2
100V1=200(1/2 V1)
100V1=100V1
which both of them are equal!
does the 1/2 factor simplify the pressure down to 100? and have nothing to do with the volume? just like u said before
If I didn't know all this would I use 200 kPa or simplify it down like that and use 100 kPa using 1/2 factor from volume?
I know its a lot of questions.. but please help me clarify this.. thanks.
P1V1 = P2V2
The pressure * volume is the same before and after
So if the volume after is half then the pressure is twice as much.
V2=0.5V1
P2 = P1/0.5 =2*P1
Pressure at surface is 100KPa so pressure underwater must be 200KPa
You are told that each m of water gives you 10KPa so to get an extar 100Kpa you need 100/10 = 10m of water
  • · Replies 18 ·
10K
