Motion in Magnetic Field : Co-Ordinates
The discussion revolves around finding the coordinates of a charged particle undergoing uniform circular motion in a uniform magnetic field, as well as exploring helical motion. Participants engage in both theoretical and mathematical reasoning regarding the motion of charged particles in magnetic fields.
  • One participant inquires about determining the coordinates of a charged particle in uniform circular motion and expresses difficulty with the complexity of using angular velocity.
  • Another participant provides equations of motion for a charged particle in a magnetic field aligned with the z-direction, suggesting that these can be solved using differential equations.
  • A later reply mentions that once velocity is determined, position can be found by integrating the velocity vector.
  • One participant asks how to prove that the trajectory of a charged particle with velocity in the i direction and magnetic field in the -k direction must be circular, indicating a need for clarification.
  • Another participant asserts that the equations provided earlier are derived from Newton's Second Law and explains how they relate to the motion of the particle, suggesting that solutions can be expressed in a parametric form representing a circle.
Participants generally agree on the application of Newton's Second Law to describe the motion of charged particles in magnetic fields, but there is some uncertainty regarding the clarity of the explanations and the need for further elaboration on the proofs of circular motion.
Some participants express confusion about the application of the equations and the proofs, indicating potential gaps in understanding or assumptions about prior knowledge of differential equations and motion in magnetic fields.
HIGHLYTOXIC
Is there any way we can find the co-ordinates of a charged particle undergoing uniform circular motion in uniform magnetic field, in space ?
I tried it using the angular velocity of the particle but it becomes quite complex..
Can anyone help? How about co-ordinates in Helical Motion? Any Chance?
Yes - it's pretty straightforward. For example, take the magnetic field to be in the [itex]\hat z[/itex] direction and your equations of motion become
[tex]\frac {d v_x}{dt} = \Omega v_y[/tex]
[tex]\frac {d v_y}{dt} = - \Omega v_x[/tex]
[tex]\frac {d v_z}{dt} = 0[/tex]
where [itex]\Omega[/itex] is all the magnetic field, charge and mass folded into a single parameter. You shouldn't have any difficulty solving them if you have any experience with differential equations.
Oh, and once you have the velocity you can find the position by integrating
[tex]\frac {d \vec x}{dt} = \vec v[/tex]
Yeah, that does make it simple..Thanx for the help!
How would you prove using Newton's Second law that the trajectory of a charged particle with Velocity in the i direction and magnetic field in the -k direction must be circular?
The preceding posts showed exactly how to do that.
Would you be able to lay it out for me because I don't understand that?
Steve,
The equations I wrote in Post #2 in this thread ARE Newton's Law! Acceleration is force divided by mass and you see the left side of the equations represent the acceleration vector. The right side of the equations are the force vector [itex]q \vec \times \vec B[/itex] divided by the mass (I rolled all the constants into the constant [itex]\Omega[/itex].
If you can solve those equations then you have your answer. You should at least be able to convince yourself that [itex]\cos \Omega t[/itex] and [itex]\sin \Omega t[/itex] are solutions of the first two equations so all you would have to do is apply initial conditions to the general solution
[tex]\vec x = \hat i x + \hat j y = \vec a \cos \Omega t + \vec b \sin \Omega t[/tex]
to find the constants a and b. The result is a parametric representation of a circle!
  • · Replies 17 ·
  • · Replies 16 ·
