Probability with normal distributions
The discussion focuses on calculating the probability that Smith returns to point A after Jones arrives at point B, given their respective travel times follow normal distributions. Smith's travel time is modeled as a normal distribution with a mean of 5 minutes and a standard deviation of 1 minute, while Jones's travel time has a mean of 15 minutes and a standard deviation of 2 minutes. The key calculation involves determining P(4 + X > Y), where X and Y represent the travel times of Smith and Jones, respectively. The conclusion confirms that the probability Smith has returned to A when Jones reaches B is relevant to the problem.
  • Understanding of normal distributions and their properties
  • Knowledge of conditional probability concepts
  • Familiarity with statistical notation and terminology
  • Ability to perform calculations involving random variables
  • Study the properties of normal distributions in depth
  • Learn about conditional probability and its applications
  • Explore the use of statistical software for probability calculations
  • Investigate the Central Limit Theorem and its implications for normal distributions
Students studying statistics, mathematicians, and professionals involved in probability theory or data analysis who need to understand the implications of normal distributions in real-world scenarios.
thereddevils
The time taken by Smith to travel from A to B is a random variable which follows the normal distribution , with mean 5 minutes and standard deviation 1 minute. The time taken by Jones to travel from A to B follows the normal distribution with mean 15 minutes and SD 2 minutes and is independent of the time taken by Smith. Smith and Jones start to move from A to B at the same time. Smith takes only 4 minutes to reach B and then he returns to A. Determine, up to 3 significant figures the probability that Smith will return to A after Jones arrive at B.
Do i calculate the probability that Jones take less than 4 mins to reach B? If so, the probability is simply 0 so this is wrong.
Or do i take this as a conditional probability question since Jones is known to have arrived at B? If so, i am stucked here.
Smith's time is 4 + X where X ~ N(5,1).
Jones's time is Y where Y ~ N(15,2).
You want to find P(4 + X > Y).
This is assuming the time it takes to get from B to A has the same distribution as the time to get from A to B.
thanks awkward, that seems to be the probability that smith has returned to A once jones reaches B.
i interpreted it as the prob that smith is about to move from B once jones has reached B but this probability is 1 so i will take your suggesttion. thanks!
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 35 ·
  • · Replies 26 ·
