Calculating Energy Eigenvalues & Eigenfunctions for a 2D Particle
The discussion revolves around calculating energy eigenvalues and eigenfunctions for a two-dimensional particle in a defined rectangular region, as well as determining the reflection coefficient for a particle encountering a potential barrier. The scope includes theoretical aspects of quantum mechanics and problem-solving related to Schrödinger's equation.
  • Homework-related
  • One participant describes the scenario as a "potential well" and suggests solving Schrödinger's equation with energy set to zero inside the rectangle.
  • Another participant presents a proposed eigenfunction and eigenvalue equations, detailing the calculations for the three lowest energy states.
  • Some participants express confusion regarding the two-dimensional aspect of the problem.
  • There is a repeated inquiry about the reflection coefficient for a particle with kinetic energy incident on a potential barrier, with a request for an expression in terms of the ratio ε = E/U.
  • A participant shares a link as a potential resource for understanding the reflection coefficient problem.
Participants do not reach a consensus on the calculations or approaches, with some expressing confusion and others providing differing insights. The discussion remains unresolved regarding the reflection coefficient and the two-dimensional eigenvalue problem.
There are limitations in the clarity of the two-dimensional calculations and the assumptions regarding the potential barrier's characteristics. Some mathematical steps and definitions may be implicit or not fully explored.
Franco
let's say..
there is a particle, with mass m, in a 2-dimensions x-y plane. in a region
0 < x < 3L ; 0 < y < 2L
how to calculate the energy eigenvalues and eigenfunctions of the particle?
thx :smile:
and.. 2nd question..
there is a particle of kinetic energy E is incident from the left on the potential barrier, height U, situated at the origin. The barrier is infinitely wide and E>U.
how to get an expression for the reflection coefficient R of the particle, as a function of the ratio ε= E/U
and how would the sketch look like?
:cry: i don't really know how to work them out...
Basically, you are talking about a "potential well" in which the energy is taken to be 0 inside the rectangle, infinite outside. You need to solve Schrödinger's equation with Energy 0 inside the rectangle. This turns out to be one of the few situations where it can be solved exactly. The solution consists of "standing waves" (just like waves on a rubber rectangular sheet fixed at the boundaries).
i don't understand when it comes into 2 dimension :(
can someone help me see if these look right?
π = pi
E1 + E2 = E
Eigenvalue :
ψ(x,y) = A sin [(n1 π x) / (3 L)] sin [(n2 π y) / (2 L)]
Eigenfunction :
E = E1 + E2 = [(n1^2 π^2 ħ^2) / (6 m L^2)] + [(n2^2 π^2 ħ^2) / (4 m L^2)]
E = [(π^2 ħ^2) / (2 m L^2)] * [(n1^2 / 3) + (n2^2 / 2)]
for the 3 lowest energy
E11 = [(π^2 ħ^2) / (2 m L^2)] * [(1^2 / 3) + (1^2 / 2)]
= (5 π^2 ħ^2) / (12 m L^2)
E12 = [(π^2 ħ^2) / (2 m L^2)] * [(1^2 / 3) + (2^2 / 2)]
= (7 π^2 ħ^2) / (6 m L^2)
E21 = [(π^2 ħ^2) / (2 m L^2)] * [(2^2 / 3) + (1^2 / 2)]
= (11 π^2 ħ^2) / (12 m L^2)
http://electron6.phys.utk.edu/qm1/modules/m2/step.htm
Nor do I, but here's a jumping point if it'll help. . . my brain doesn't work after 1:00am EST :biggrin:
