Point charge inside solid sphere
The discussion revolves around the behavior of a negatively charged electron placed inside a solid, positively charged sphere with a uniform charge distribution. Participants explore various theoretical implications, including the nature of electric fields within different configurations of charged spheres, and the stability of the electron's position.
  • Some participants suggest that the electron would tend towards the center of the sphere and reach a sort of equilibrium, although one participant notes that it would inevitably have some residual momentum and would not remain motionless.
  • Others argue that the electric field inside a uniformly charged sphere is zero, but this is contested based on whether the sphere is conductive or insulating.
  • A participant points out that if the sphere is an insulator, the electric field inside is proportional to the distance from the center, leading to a different behavior for the electron.
  • There is a discussion about the implications of "uniform" charge distribution and the physical feasibility of such a configuration, with one participant expressing skepticism about the concept of uniformity in three-dimensional systems with multiple point charges.
  • Another participant introduces the idea of approximating uniformity and suggests that a greater number of charges would improve this approximation, potentially leading to a more stable electrostatic solution.
Participants express multiple competing views regarding the behavior of the electron and the nature of the electric field within the sphere. There is no consensus on the implications of uniform charge distribution or the physical realizability of the scenario described.
Limitations include assumptions about the nature of the sphere (conductive vs. insulating) and the definition of "uniform" charge distribution, which remains unresolved in the discussion.
leonidas24
I'm curious. Say you have a solid, positively charged sphere with a uniform charge distribution. Now suppose you place a single, negatively charged electron inside the solid sphere. How will the electron behave? I assume the electrostatic forces exerted on the electron will ultimately tend it towards the center, where it will reach a sort of equilibrium and remain there motionless?
Sort of.
In fact, you couldn't place it so carefully that it wouldn't have some residual momentum.
It would move around, and the other charges involved would move in response. It's a pretty chaotic situation with no real stable equilibrium, like balancing a pencil on it's point.
Inevitably it would come into close proximity with one of the other charges and they would neutralise one another.
the electric field inside a uniformly charged sphere is exactly zero. this was first proven by Newton for gravitational forces.
As long as you don't disturb the status quo by trying to stick a charge in the middle.
Of course, it returns to zero after the intruder has been dealt with.
He didn't say the sphere was conductive, so I assumed that the charges are rigidly stuck on the sphere.
Hmmm... theoretically yes, but is that physically possible do you think?
This problem is theoretical. Also, if it was a conductor, then there is the Thompson's theorem that a point charge can never be found in a state of stable equilibrium in an electrostatic field.
You didn't mention the approximations you want to assume. In classical electromagnetism, neglecting the electron's field, inside the sphere you have field directed radially with amplitude proportional to the distance from the center. So it's like the electron is linked to the center with an ideal spring. The resulting motion is an ellipse. In time the electron will lose energy and spiral down the center.
It's true only if the sphere is a conductor. But if the sphere is an insulator, then you can easily prove (by Gauss law) that the electric field inside the sphere is proportional to the r, the distance from the center (r<R radius of the sphere). Hence, exactly in the center of the sphere, the electric field is zero and because the electron is point charge we can assume that it will remain in the center in equilibrium.
Ok, ok, I thought "sphere" means a spherical shell, not a uniformly charged ball.
If it is a uniformly charged spherical shell, then the electric field inside is zero.
If it is a uniformly charged ball, then the electric field inside is radial and the magnitude is proportional to the distance from the center, reaching its maximum value:
[tex] E = k_{0} \, \frac{Q}{R^{3}}[/tex]
on the surface of the ball [itex]r = R[/itex].
This problem is quite similar to one that I've published on. However, I would never assume that any three-dimensional system consisting of more than 4 point charges is "uniform". (What is meant by "uniform"?!)
In this case, perhaps we are talking about the original Thomson problem (or, perhaps the jellium model that many today love and adore) in which Thomson assumes that the atom consists of negatively charged electrons (corpuscles) in a "uniform" positively charged volume. But, with our knowledge of atomic structure today, having particulate structure, what does "uniform" mean? With five point charges, one can never place all of them in a three-dimensional volume such that they are all equidistant from each other. At best, you could find a configuration in which they may all have the same electrostatic energy.
..basically, my argument is that this question is physically impossible, not so much because of so-called 'quantum-fluctuations' that prevent a negative point charge charge from actually finding, and residing at, the origin of the sphere, but because there is no such as a perfectly "uniform" volume of charge. ...those charges are particles.
Now, if we are discussing "an approximation to uniformity", then the greater the number of charges there is in the positive sphere, the better that approximation. Then, we might as well consider a metallic system because all the spatial symmetry properties of the "uniformity" must be "washed out".
While this may seem like a trivial point to make, I assure you that it makes a world of difference in the final analysis. Of course, if you're looking for a statistical-natured argument (e.g. quantum or density functional), then by all means, this is a trivial point. But if you're looking for a true electrostatic solution, then this point is of utmost importance.
Just some thoughts.
===8<-----------------
10K
  • · Replies 19 ·
