What Mineral is in My Wife's Pebble Water Fountain?
  • Thread starter Thread starter DaveC426913
The discussion revolves around identifying the mineral composition of crystals found in a pebble water fountain after prolonged use and evaporation. Participants explore potential origins of these crystals, considering both the pebbles and the tap water as sources.
  • Exploratory, Technical explanation, Debate/contested
  • One participant describes the crystals as opaque creamy white or very pale yellow, suggesting they may have formed from minerals dissolved from the pebbles over time.
  • Another participant proposes that the crystals could simply be remnants of the original calcium carbonate pebbles, altered by water exposure.
  • A different viewpoint emphasizes that the crystals are distinct and have grown separately in the reservoir, potentially from impurities in the water rather than the pebbles themselves.
  • One participant suggests that the crystals might be sulfates, possibly calcium sulfate, which could precipitate from tap water during evaporation.
Participants express differing views on the origin of the crystals, with no consensus reached on whether they are remnants of the pebbles or formed from tap water impurities.
Participants note the importance of the angle of the crystal faces and the characteristics of the crystals, but these details remain unresolved in determining the exact mineral composition.
Individuals interested in mineral identification, water chemistry, or the effects of evaporation on mineral deposits may find this discussion relevant.
DaveC426913
2025 Award
I finally got around to cleaning out my wife's desktop pebble water fountain. It has been abandoned for a long time and the water has evaporated. I thought the reservoir was filled wih little bits of straw, but upon closer examination, see that they are all little crystals. The water obviously spend a lot of time trickling over the pebbles, and sitting in its reservoir of slate, so I imagine it's dissolved some minerals from there.
They're ~5mm long and .5 wide and of nearly uniform cross section end-to-end - few imperfections. I can't quite tell the angle of the faces, which is an important clue, right? They are opaque creamy white / very pale yellow. They don't look shiny, they look as if they'd feel like straw to the touch.
What mineral do you suppose these crystals are?
Chemistry news on Phys.org
Hello,
As the first option, we may consider this material as a "crushed" pebble. So pebble is a calcium carbonate mineral (if I am not wrong); and water can remove some from it, revealing shiny crystals behind.
To sum up, I don't think it is different than the material used for manufacturing; it is plain pebble in my opinion, just etched by water a bit.
Unless I misunderstand, it seems that you're suggesting these aren't crystals that grew in place, that they're left over from a dissolved pebble?
No, these are quite distinct crystals that have grown, physically separated from any pebbles, in the bottom of the water reservoir. The pebbles are not in the reservoir, they are on top, only water is (or rather, was) in the reservoir.
Whatever mineral they are has been grown from impurities that were in the water. Clearly, this mineral is most likely dissolved off the pebbles that the water had been running over all this time, before it evaporated. However, alternately, it could have been something in our tapwater.
Well, as a second option, we may think of this crystals' origin as the tap water just like you suggested. Tap water contains many minerals, and if their amount is sufficient, evaporation may cause some of the less dissolving materials behind as imperfect, somewhat "dirty" crystalline solids. They are probably sulfates, maybe calcium sulfate, which has less solubility in tap water than nitrates, chlorides, and so on.
Regards,
chem_tr
  • · Replies 21 ·
